Question about Hotpoint Refrigerators
FF200EP Fridge Freezer - water leak at bottom front of freezer door and ice forming at bottom of freezer.
  • 4 more comments
  • myronuk Feb 14, 2009
    Frost free!!!!
    The problem had to be resolved quickly - no fridge/freezer - and so I called in their service dept.
    Surly chap, defrosted the back with a hair dryer, Hotpoint charged just under £100 for this, even though F/F was only 1yr 2 wks old.
    Will never buy Hotpoint again.
  • Anonymous Mar 13, 2014
    Water leaking on floor
  • Anonymous Mar 14, 2014
    ice sheets form on bottom of freezer. it seems to be running stream of water from the condesnser vents in the back.
  • Anonymous Mar 15, 2014
    ice leak under bottom freezer
  • Anonymous Mar 17, 2014
    I have a Kenmore fridge... freezer on bottom and the seal from the top door is leaking, any ideas why?
  • Anonymous Mar 30, 2014
    My Samsung fridge/freezer is leaking at the bottom where the freezer is situated. I have cleared it out and made sure the door is closed properly but still happens. Any help
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
What is wrong when the icemaker leaks into the inside of the fridge
ok unplug frig open freezer door empty ice let freezer door stay open for a few hours ice has formed where the ice cube water comes into it. ice built up and water sprays every where but where it should
Aug 19, 2014 | Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Ice forming in bottom of freezer and water leaking in front by freezer door. Model GSH25KGMC
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | GE Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
577 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
