Question about Cameras
Tamron SP 17mm F/3.5
I recently purchase what was described as a new (never used) Tamron SP 17mm F/3.5. It came and looked new. When I tried out the lens I found that the shutter would not open. I believe it may have been dropped. There is a loose part inside. I see a set of three screws that I think would open the lens to the shutter compartment. Do you think that the shutter is replaceable or is there a manual someplace that I could look at.
cammedic
  • 667 Answers
SOURCE: Tamron 28-300 loose lens parts
The way in to this lens is from the rear. You'll need to remove the trim ring inside the mount and free the electronic connector from the mount ring before you remove the mount ring itself.
Posted on Jan 19, 2008
SOURCE: Tamron sp 17mm 3.5 has unscrewed
it would be great to be able to see some les diagrams hey
Posted on May 22, 2008
  • 149 Answers
SOURCE: tamron 35-105 f2.8 sp lens, aperture often
lens flexible pcb broken change it
Posted on Sep 09, 2009
  • 102366 Answers
SOURCE: Tamron 200-500mm F5-6.3 SP AF
Assuming the lens has a Nikon mount, yes.
Posted on Dec 02, 2010
SOURCE: Dropped my 28 - 75 2.8 tamron lense and will not
I Have a problem qith the Tamron 28-75Aspherical Lens XR Di for Canon mount. Just make a strange sound like to power on the iris motor when you insert the lens to the camera body. I just disarmed totally it, but the problmes seems to be with the electronics parts.
If you are interested I will sell the lens to you or you can sell your broken lens to me. For contact please write to partgio @ hotmail . com or to partgio @ yahoo. com or partgio @ gmail.com
Thanks in advance, all the best
Giovanni
Posted on Mar 24, 2011
Tamron 90mm macro lens communications error
Hi this is problem of innner flex damaged so just replace this flex and its done
If you want any more help
Khatricamera@gmail.com
Pic is attach only for your knowladge its not for your lens
Its like this
Apr 13, 2013 | Tamron SP AF 90mm f/2.8 Di Macro 1:1 Lens
Tamron 14mm 2.8 does not work on d90
This lens is compatible with your Nikon D90 according to this site:
http://lenshero.com/lens/Tamron-14mm-f2.8-IF-Nikon-f-lens
Your complaint "does not work" is rather broad, so I don't know what specific kind of problem(s) your having with it.
If you continue to have issues with it, make sure other lenses work on your D90 to eliminate the body as the source of the problem. Consider performing a 2 button reset on the D90 (and resetting any other customized settings to defaults) and try again. If it still "doesn't work" then contact Tamron to evaluate the lens for possible repair.
Jan 05, 2012 | Tamron Super Wide Angle SP AF 14mm f/2.8...
Where to locate serial numbers on my new lens
My Tamron 18-270 has number at bottom side toward tripod hole(when lens is mounted on body)
May 07, 2010 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
Nikon D40x
you will not have AF...only MF
full list of compatible lens for your camera here
Oct 16, 2008 | Tamron SP AF 11-18mm f/4.5-5.6 Di II LD...
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Jan 15, 2008 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Cameras Logo
122 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
