Twain drivers Hi, I want to know if my scanner is twain compliant or not. I m having hp photosmart c4288. If its not twain compliant from where can i find twain drivers for windows xp.
The problem was with the scanner,it was not twain compliant
So the 2 ways left with me was :
1.Download twain drivers for my scanner and install it.
2.Use wia32.dll
I chose second option as i didnt found any twain driver for my scanner.
Hope this can help any one.
Posted on Aug 30, 2008
Error 2148285
What driver are you using no twain suggests that the driver is not twain compliant. You may need to update the driver with the correct operating system like windows (whatever it is) or is it MAC OS .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/fi-series.html
Apr 21, 2014 | Fujitsu Fi-4120c2
There is no twain compliant device installed please install one and try again this is the error message was getting while scaning the page. please help me out..
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Aug 29, 2011 | HP Laserjet M2727nf Multifunction Printer
How do I scan 35 mm slides on my C3180 all in one printer/scanner?
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
If I try and scan from my 6380 All in one it tells me to start the scan from the computer it wont do it from the printer and have no idea how to do it starting from the computer as the guide book only...
If you have Vista or Win7, go to Windows Fax and Scan and import from the scanner. You can also do this from Microsoft Paint or your preferred scanner software (PaperPort for example). Make sure you check your scanner manual to check if the scanner is a TWAIN or WIA compliant scanner.
CIndy Wells
Dec 09, 2009 | HP Photosmart C6380 All-In-One InkJet...
Why won't my HP Deskjet F2100 scan a image?
Try scanning from your PC, if you have a program that will allow it... if you have Word '97, you can do it like this:
  1. With your scanner ready and the image on the scanner glass, in Clip Organizer, on the File menu, point to Add Clips to Organizer, and then click From Scanner or Camera.
  2. In the Insert Picture from Scanner or Camera dialog box, under Device, select the scanner.
  3. Click Insert. The new clip appears in the My Collections folder, in a folder named after your scanner
If you do not have Word '97, but a program that SHOULD work but doesn't have the correct driver, go to www.twain.org for the latest twain-compliant drivers for your scanner! You may also be able to find a simple scanning app (in the downloads section) at www.cnet.com
Hope this helps!
-- RT
Sep 03, 2009 | HP Office Equipment & Supplies
Everything works but the scanner.
The most common reason for non-communication between a computer and a scanner is either the absence of, or errored instalation o,f TWAIN compliant software... you've probably tried re-installing the software for the printer itself, do you have any other software that has scanning capability? Try going to http://www.twain.org/ and there may be a driver available for your PSC (I had an HP All-in-one, and the issue was fixed with the driver)
Hope this helps!
-- RT
Sep 02, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart C3180 All in One - Scanner problems
twain is a driver, it could be corrupted at this time uninstall again and reinstall the software
Sep 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
Scanning
The 6180 memory device refers to the removable memory devices that can be loaded into the slots on the front of the machine, not the scanner. Your devices are configured wrong.
The scanner is a TWAIN device and therefore requires a Twain driver. Accessing Twain sources requires you to SELECT SOURCE for your scanning software.
Just un-install, re-boot, then re-install the drivers for the 6180. Make sure to allow the resident software that runs on your PC to run in the background.  HP needs the "ImageMonitor" and other software to run in order to "feed" your scanning software.
Oct 15, 2007 | HP Photosmart C6180 All-In-One InkJet...
1,430 people viewed this question
jasbo
jasbo
