Question about Maytag Washing Machines
Maytag mfw9600sq1 error f2 will not spin out - Maytag Washing Machines
Code f02 indicates that the house drain is slow or clogged. I had the same problem with my machine. To check I ran the drain house out the dryer vent to the yard. I ran the machine and it cycled through.
I snaked out my drain and cleared the J bend of lint and dog hair and now it runs great.
Another problem is that the hose is too high and the sensor that the drain is clogged or slow.
Good luck
ken.
Posted on Dec 05, 2008
  • SHEILA SAUNDERS Jul 08, 2014
    I had the same issues and finally found advice that told me to take the bottom panel of the washer off (three little screws underneath). Behind that is a drain filter and pump. Pack around it with towels to avoid water everywhere and then twist the cap open (it is shaped like a dial with a handle in the center). Clear out the filter and pump. Solved the problem.
I get a f05 error code on my maytag model#mfw9600sq1
This is a drain error code. Lucky for you there is a kick-plate at the bottom with 3-4 screws at the very bottom. Remove the kick-plate and you'll see the drain pump with a round access port. (sometimes I have to use a pair of pliers to open this up - turn counter clockwise). Note: Any water inside the unit is going to come out so be prepared. (bunch of towels needed) The water will probably stink really bad too. Once you open that up hopefully you will find debris blocking/clogging up the unit. If so put it back together and TA-DAA! You're done!
Now, if you find nothing you'll need to replace the pump.
pt# 280187
Here is where you can purchase part.
Appliance Parts
The reason these pumps burn out so often is because the impeller is made of plastic and it only takes a customer not checking their pockets once to have a penny come out and into the pump causing damage. Even if you are lucky and find debris in the pump and able to get it working again you may want to consider replacing the pump anyways.
Thanks
Feb 04, 2015 | Maytag Washing Machines
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Sep 19, 2014 | Washing Machines
F2 error for MAYTAGE CRE9500 electric range
Here is the definition for the F2 code from Maytag...
F2 Oven temperature too hot. Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.
Jun 04, 2010 | Kitchen Ranges
I have a Maytag front load Mod. # MFW9600SQ1. When
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Jan 30, 2010 | Maytag EPIC MFW9600S
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
624 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
