Question about Altec Lansing 621 Computer Speakers
Suddenly no sound out of left channel
For no apparent reason my left channel won't work from the speaker but will from the headphones. I swapped speakers and confirmed that it isn't the actual speaker sounds fine. I took the sub apart to check continuity and for blown fuses or a burnt component but found nothing wrong. Anyone have any other suggestions? Thanks
  • blkcotton May 11, 2010
    do u know where i can get a remote controller for the system
    New Friend:
I have the Altec Lansing speaker set ACS48, they are old but the right one works fine, the left one doesn't at all. I found that there is a processor in the right speaker, and I think that could be bad or the driver is not loaded for some reason, so I am lost as well....anyone? contact me at joeinslw@gmail.com if you know and have a solution Thanks.
Posted on Feb 13, 2015
Sorry, no I don't.
Posted on Sep 22, 2008
  • MBickman08 Nov 05, 2010
    I am having the same problem. Retire them.
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Sound is only coming out of one side.
check speaker wires connected to amplifier try to swap it between right and left speaker do the same to audio input jack (usually RCA jack). If it still works one channel only, probably the problem is in the power amplifier
Apr 03, 2011 | Audio Technica ATH-M30 Professional...
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
Midiland ir-hf1 right speaker broken
Hi evtan
The only thing I can suggest you do is to swap the right and left inputs to the transmitter base over whilst wearing the headphones. If the fault transfers to the other channel, then you have a faulty interconnect lead that needs to be replaced. If it stays with the same channel, then the headphones or the base staion will be faulty. Best bet then is to return it to the place you purchased it from and request a replacement unit,. Thanks for using FixYa....a FixYa rating is a great reward from you to me for helping out :) Cheers
regards
robotek
May 08, 2008 | MidiLand IRS 858 Consumer Headphones
My right speaker does not work
My left speaker didn't work, I described how I fixed it here: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Jul 11, 2007 | Logitech X-230 Computer Speakers
Altec Lansing 621 Computer Speakers Logo
288 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
