Question about Kenmore Dryers
Cycles but no heat
Where can l find the igniter and the thermo fuse on kenmore gas dryer model# 11072812101
  • 706 Answers
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Posted on Aug 31, 2008
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer does not heat
Clean it up and replace the fuse amigo Older models have the fuse to the rear39b9f91.jpgabf02b3.jpgnewer models have it on the blower housing. Post yer model number for a better answer friend.5d0f07f.jpg
May 08, 2010 | Kenmore 73952 Gas Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Gas dryer no heat
There are many things it can be, does it ignite at all? do you get voltage to the igniter? whirlpoolpartssurplus.com open still give me a calll and we can talk for free..
Jun 24, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore gas dryer wont heat, model #11074832400
check the igniter,thermal fuse,operating themastat there is a small plastic piece on the lower left hand corner pop that out and when you turn your dryer on it should be glowing red if not its the igniter
Mar 01, 2008 | Kenmore 63942 Dryer
Kenmore dryer model #11071804000
thay can go bad soon but ck the thermo fuse on the dryer its a white fuse on inside dryer that will fix it 98% time
Feb 25, 2008 | Kenmore 63942 Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Dryers Logo
142 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
