Question about HP PSC 2210 All-In-One InkJet Printer
Paper jam I have a lexmark 5400 and now it's having this problem so far i have printed two sheets and about 20 in the trash, can you help me
    Genius:
  • 1,665 Answers
It is possible you are not using correct paper type. See your manual's instructions.
Posted on Aug 30, 2008
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Paper Jam Problems
go the control panel and go to the printer then open the printer that you are using!! you need to cancel all printing document and after you done this.......just restart your pc
Jun 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Printer says clear paper jam. There is no paper jam.
Dec 31, 2008 | Lexmark X5250 All-In-One InkJet Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper jam
It is very touchy. If the paper is in too far, you get the paper jam message, if you don't put the paper far enough down, you get the paper empty message. Try installing about 5 sheets at a time and after aligning them into the slot, lightly tap the 5 with the palm of you hand untill you feel the first stop. The second stop will be to far. Try putting it in too far so that you can get the feel for both stops.
Apr 12, 2008 | Lexmark P315 InkJet Photo Printer
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
HP PSC 2210 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
