Question about Palm Treo 650 Handheld
Deleting Outlook contacts
I inadvertently imported an unclean outlook address/contact list. How can I delete these from my Treo 650 and re-import the list after I clean it in outlook? Thanks
    Master:
  • 473 Answers
You'll also need to follow the instructions above to delete these files in FileZ: AddressCitiesDB AddressCompaniesDB AddressCountriesDB AddressStatesDB AddressTitlesDB ContactsBDIndex-PAdd ContactsDB-PAdd Then your Contacts on your handheld should be totally wiped. Again, exercise caution when doing this.
Posted on Sep 11, 2005
    Master:
  • 473 Answers
FileZ file utility lets you delete the AddressDB on your Treo Your best bet would probably be to wipe the Contacts database on your Treo 650, then re-sync. 1. Install FileZ on your Treo 650, Why? Because the Contacts DB is not accessible from the built-in system; you need this extra file manager to delete it. 2. Launch FileZ and find this item: AddressDB. 3. Tap on AddressDB to add a checkmark next to it. Hit Details. Hit Delete. 4. DON'T HOTSYNC YET! Just in case, export your Outlook Contacts and store in a safe place. You'll be syncing to a blank address DB on your 650, and although it shouldn't overwrite your Outlook data wwith the blank DB ... better safe than sorry. 5. Now you can HotSync to Outlook.
Help out a New User
all you need is to sycronize it. page 33 in the user guide: http://www.fixya.com/BrowseManual.aspx?mnlid=945&prdid=289812&__PAGED_=33
Nov 16, 2005 | Palm Treo 650 Handheld
Treo 650 Sync w/ Outlook 2003
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Sep 19, 2005 | Palm Treo 650 Handheld
Syncing Problem w/ Full Name in Outlook
Down grade your msoutlook to 2000 or update it to 2003 better yet reinstall your whole win sys.
Sep 12, 2005 | Palm Treo 650 Handheld
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sync to Public/Shared Folders in Outlook
Yes you can. You can sync to public folders using Chapura’s Keysuite, which allows you to choose the folder (or folders) you want to sync to. I have been doing so for years with different Treos, and in fact their synchronisation software is much better than that which comes with the Treo 650.
Sep 11, 2005 | Palm Treo 650 Handheld
Hot sync Outlook 2003 business contacts and accounts to Treo 650
Thanks to a fellow user, I was informed that I needed to purchase Chapura software. The following link has the software that does two way sync with BCM. Others don't. I did however have a few problems, but the help desk through Chapura was able to get the process working. Good Luck.
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Can you change from Palm to Outlook on your Treo 600
Simplest method for 'switchers': Assume that your Treo 600 has the data you need (it does but you are focusing on your Palm Desktop in your question). Install the Palm Desktop software again using the CD but this time, choose the option to synchronize with Outlook during the installation process. This will switch the synchronization to Treo <-> Outlook instalead of Treo<->Palm Desktop. Assuming your Treo is recently synched with Palm Desktop, this will merge the data you have in the Treo with that of your Outlook profile.
Sep 11, 2005 | Palm Treo 600 Handheld
Palm Treo 650 Handheld Logo
166 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
