Question about Tivo DirectTV Remote Remote Control
Help quick i have a tivo series 2 that i got and no remote, the model ### on the back say tcd540040 and i need a owners manual and a remote control, can you help at all????? willie
  • 2,794 Answers
Goto tivo.com to get your remote and the manual is available on the website as well for your Tivo.
Posted on Sep 12, 2008
Rcr314wr need tivo series 2 code
RCA remote control have no set-up code/s to Tivo brand TVs. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 21, 2014 | RCA Televison & Video
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
My Virgin Media Tivo Remote is not working with my Easy Touch 42 inch TV, I have not been able to find the Code on the Database, can anyone help ?
Since you haven't mentioned the EXACT model of your remote, I can't exactly tell you the instructions. BUT you may choose your EXACT remote and refer to the instruction / codes from this link:
Virgin Media Remotes
I hope this helped you.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 14, 2011 | Tivo Series 2 Remote Control
I need the remote (RC23) code for a series 2 Tivo Model TCD54008
if the remote is RC23, the tivo codes are 01442 & 01142. If you actually have a Rc16, then you can only control the tivo partially with code 20618 on either AV1 or AV2 device slots.
Jul 31, 2009 | Directv RC23 Remote Control
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Can a tivo series 2 be modded to use as a dvr without subscribing
No. But, i belive the series 2 will allow you to "create a mnual recording" .... so, if you know the time and channel your proigram is on, it will record. Keep in mind that you won't know what program is what since you haven't downloaeded the program titles....
May 22, 2009 | Tivo TCD540040 700-Hours Video Recorder
Trying to set up tivo series 2 without remote
There are different codes depending on whether the Tivo was set to respond as a specific device (1 or 2) on the remote or by standard default (device 0). Also, typically each universal remote has its own code for each device, which is specific to the remote, not the device you wish to control. For the $20.00, it might not be a bad thing to simply buy a new universal remote that is capable of controlling a PVR (There are many good ones out there).
Mar 15, 2009 | Humax DRT400 TiVo 40-Hours Video Recorder
Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Nov 22, 2008 | Vizio L37 Television
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirectTV Remote Remote Control Logo
123 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
