Question about IBM ThinkPad T22 2647 Notebook
Laptop freezes up
I own a ibm thinkpad t22 (2647) and lately without warning it completely freezes up after 20 mins of use.I have 256 mb of ram and computer worked fine for a year. I usually do computer clean ups,scan for viruses(none),regularly clean out cookies and defrag it.If i reboot it still freezes up. Please help.Also is there a 512 mb ram or do you have to buy 2 -256 mb ram.
  • 1 more comment
  • kasey2374 Aug 30, 2008
    As a matter of fact,the laptop does get very hot on the bottom plus the battery doesnt last long on its own.We are running Windows XP and our common sites would be E-Bay and Facebook. Maybe we should replace battery ?
  • cj2546 Jan 18, 2009
    my laptop freeze, i changed harddrive-nil fix.
  • Roberta Smith
    Roberta Smith May 11, 2010
    adding more memory is always a good option. lots of variables to a computer freezing up. what operating system are you using. what programs are you running when it freezes... and one other thing tho it usually causes the computer to shut off.... is it extremely hot on the bottom ?
  • 2,028 Answers
Yes you can get a 512mb chip for this. As for the freezing, it could be a number of issues, anything from a software glitch or conflict, to a failing hardware component. Start by going to, downloading and running CCleaner. If it's a glitch, this cleaning program should clear it. It it continues, the first thing to try is removing the battery and see if it's still freezing. Batteries are notorious for causing this. Then try a system restore back about a month or so. It could also be that the programs you're currently running need more resource than 256mb in the memory, so tadd the 512mb chip and see if that cures it. If it persists after you try these, get back to me, and we'll see if we can figure it out.
Posted on Aug 30, 2008
Need to upgrade my ram from 256 to 512
Search Amazon for 256 mb modules. I found some today.
Mar 05, 2014 | IBM ThinkPad T22 2647 Notebook
Some of the old laptops hold a MAX of 64, 126 256 mb pc66 or pc100 ram... and...
There are actually a few things you can do for a dinosaur laptop (other than waiting for the asteroid to appear in the sky). Here are my top three suggestions:
  1. Squeeze in as much RAM as possible. If you have a spare SIMM slot, put in the largest-capacity module you can find. You may have to throw away what's already in there--likely a 16MB module--and replace it with a 32MB or 64MB one. Memory was so expensive five years ago that vendors often skimped on it, but now that prices have plummeted, you should pack in as much as possible. (You may also look around for a chip doubler--a SIMM two-for that lets you put a pair of chips where there's only room for a single.)
  2. Get a huge, honking hard drive. You should be able to dig up a compatible 10GB or 20GB drive. What's great is that it'll run at 4,200rpm (compared to the 3,600rpm drive you currently have), which will result in better performance. Save all your precious data, swap the old drive out for the new, and fire it up (crossing your fingers that the OS sees the new drive). Take note: You'll have to preload an operating system onto the new drive or load it on the fly.
  3. Accelerate. You'll want to configure Windows to run your hard disk and graphics card at their maximum speeds.
  • Hard drive: Go to the device manager, select the drive letter, and pick the Settings tab. Check DMA for best performance. For Windows 2000, go into the hard drive's properties, open Disk Properties, and check Write Cache Enabled.
  • Graphics card: On your desktop, right-click and select Properties. Select the Advanced tab, then click the Performance tab. Push the slider all the way to the right.
on Jul 17, 2008 | Acer Aspire 3690-2196 Notebook
Can I increase the ram in my think pad?
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
How can I upgrade memory from 256MB?
Check any free memory slots available in the laptop and upgrade the same.
Revert back for assistance.
Jan 20, 2010 | IBM ThinkPad R32 2658 Notebook
After adding 256 MB with existing 256 MB showing only 256 MB in BIOS instead of 512 MB
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
Jan 07, 2010 | IBM ThinkPad T30 2366 Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I want to no that wich ram short for the IBM thankpad r51 model
I request you about IBM ram that is short to IBM thinkpad R51 model is 256 MB.
Apr 27, 2009 | IBM ThinkPad R51: R51 P M 745 1.8GHz,...
How much?
as it seems from link 256 MB
Jan 26, 2009 | IBM ThinkPad 600E 2645 Notebook
Upgredation of ram
Here are info about that:
2 SODIMM 200-PINS Sockets
Supports DDR2 400/533 Unbuffered Non-ECC Memory
Supports maximum memory capacity up to 2GB
I recomend you to change both of them
I hope this info is helpfull for you
Good luck
Dec 11, 2008 | IBM ThinkPad R52 Notebook
Windows 98 insufficient for downloading photos from digital camera
Use Windows XP, Have more that 256 MB RAM, and 1 GHz CPU. Cheers - Parveen
Feb 07, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T22 2647 Notebook Logo
133 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
