Question about Pioneer Elite VSX-9100TX Receiver
Sound on cd but not on any other input
I get great sound when I am listening to my cd changer but the HDMI and composite's are playing nothing through the receiver they are however pushing the video/audio through to the tv just fine which leads me to belive it is a setting or combination of settings that need to be switched. This thing is more complex than the first space shuttle launch.
thanks,
matt
I have the same problem myelf and i just solved it...check the audio output from your video player..it has to be set to hdmi or whatever you are using for music output. mine works awesome again....
Posted on Sep 24, 2008
What would make speakers sound bad from a CD Changer?
It could be the cd changer is over driving the amp. IF you don't have the right input and output impedence then it sounds bad because the amp clips the signal.
Aug 02, 2014 | Pioneer Car Audio & Video
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Number of inputs
Each CD Player has audio out put amplifier circuit and this output amp remains Mute until it receive signal to out it. While using Y-Connector, when you try to listen one player sound, other goes to Mute as its in Stop position and caused to minimize the out put of other player which is being played. That's why you listen good sound if just one is connected. If you want to connect both players at one amplifier, you need at-least 2 inputs in amplifier and since your Fisher amp has not 2 inputs, so I suggest to buy another amp equipped with 2 or more inputs. Hope this info will help you.
Aug 17, 2008 | Audio Players & Recorders
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Vizio GV42LHDTV - No video inputs
my 42 also went black, and the "vizio" logo in front indicates as if it is turned on, it clicks on and off, but just has no output on the screen, meaning not a black screen, just a dead, no image, even when the system has clicked on
I tried turning off, on, unplugging, letting it sit (kind of like a reboot wishful thinking), removed all connections in back, (nothing still, not even the blue screen) just nothing.
What a shame, I had the unit less than 6 months, and now this? I have work to do, and I can't get it done.
Feb 25, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Mp3 player or ipod connection
If you have a CD changer connected it is quite easy, if not I can't imagine a solution.
With a CD changer you need a cinch-Y-cable and a cinch-to-stereo jack adaptor. You connect these two to you ipod and the second port of the cinch-Y-cable to your CD changer.
Then you can burn a CD with no sound on it, but it must not be empty! You can use NERO Waveeditor to record "nothing" for the length of one CD and then burn this file.
If you play this CD in the CD changer and press the play button on your ipod you'll hear your itunes. If you play another CD in your CD changer while listening to your ipod you'll hear both sounds.
Have fun.
Aug 12, 2007 | Sony CDX-M730 CD Player
Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Apr 08, 2007 | Clarion CDC1235 CD Changer
Pioneer Elite VSX-9100TX Receiver Logo
62 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
