Question about Palm Vx Handheld
How do I HotSync a Palm Vx with Outlook 2002
I want to HotSync my Palm Vx using OS 3.5.3 with Outlook 2002 running in Windows XP. I only have the Palm IIIc CDROM but I have downloaded and installed Palm Desktop Software 4.1.4 and the latest Conduit Updater.
    Master:
  • 473 Answers
I wish I had found you two weeks ago! That help, though simple, was fantastic - thank you. I had no idea that Pocket Mirror was on the CDROM as it was set on autostart so it launched into the Palm Software installation straight-off. I've got a few problems to sort out with it but so far it has Sync'ed the: Addresses To Do Email not yet read Calendar ** It insists on spending a very long time thinking about 'backing-up' the handheld databases and I have to force it to close. Any ideas how to solve that little problem? I'm just about to leave for Paris so I can't pursue this anymore today, so if I may I'll follow-up at the end of the week. Meanwhile thank you for your quick response and excellent instructions. Regards
Posted on Sep 11, 2005
    Master:
  • 473 Answers
You'll need a softwre like Chapura PocketMirror that you probably have on your IIIc CD-ROM
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
I use Outlook Express on Windows XP... Can I snyc this?
Outlook Express - no software included with Palm devices but There is third-party software to synchronize the email and Windows Address Book from Outlook Express to Palm OS devices. Here is a relevant link: http://www.livepim.com/expressmirror/index.htm - address book conduit to mirror the OE address book to Palm Desktop
Sep 12, 2005 | Palm Zire 21 Handheld
Windows XP, Palm m130, & Outlook 2003 - Sync problem
It sounds like the computer is noticing the USB activity (from when you hit the HotSync button) but for some reason it can't find the correct information/driver. I'd first try a soft reset (stick a paper clip or the end of your stylus may screw off to reveal a pin, in the hole at the back of your palm) Don't worry, it won't delete your info UNLESS YOU HOLD DOWN THE POWER BUTTON (SO DON'T). Once it's booted back up, try the hotsync again. If that doesn't work, you may need to find the usb driver for your palm and reinstall it. This could just be copying a file from disc, or reloading your Palm Software. Good luck
Sep 12, 2005 | Palm m130 Handheld
Compatablity with Exchange 2003
I believe you will have no problems. HotSync talks to the Outlook client rather than the server.
Sep 12, 2005 | Palm Vx Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Hot sync error 8001 with MS outlook
Answers on Chapura PocketMirror errors, Chapura maintains a really good database of fixes for errors with their PocketMirror Outlook PIM conduits. Copied from the site: First, make sure you are running the latest version of PocketMirror version 3.1.7. To check which version you are currently running, please see Chapura FAQ PM089. If you are still receiving the same error after installing the latest version of PocketMirror then continue with the following steps. If Option 1 does not resolve the issue, then move onto Option 2 and so on: Option 1: Run the Outlook 2000/2002/2003 "Detect and Repair" utility (You will need the Office/Outlook CD-ROM). 1. In Outlook click "Help/Detect and Repair". 2. After the repair is complete, reboot your computer and synchronize your handheld. Option 2: If you are running Windows XP and this error is occurring, please perform the steps in Chapura FAQ PM198. Option 3: If this OLE error occurs ONLY when synchronizing with Outlook closed, then please see Chapura FAQ PM053 "Outlook Backup Add-in causes HotSync failure when Outlook is closed." Option 4: If you have a laptop computer and are running Windows 2000/Outlook 2000, this OLE error may be caused if your laptop goes into sleep/hibernate mode when Outlook is open. To fix this problem reboot your computer and try to synchronize your handheld again. In the future make sure Outlook is closed when your computer "hibernates". Option 5: Uninstall and reinstall 3rd party conduits such as the TakeNote, DayNotez, PocketQuicken, QuickWord, Quicksheet, etc. To check for these conduits: 1. Click on the HotSync Manager icon (circular red/blue arrows on the bottom right of your PC screen, see image.) Note: The HotSync Manager icon may be hidden on Windows XP, please click the round white arrow button (see image) to unhide the icon. HotSync Manager Icon Example 2. Click on "Custom". If you see any of the above mentioned program conduits listed in the "Custom" screen ABOVE the PocketMirror conduits (Outlook Calendar, Outlook Contacts, Outlook Tasks & Outlook Notes) then uninstall any of these 3rd party programs. To do this go to "Start/Settings/Control Panel" or "Start/Control Panel" and double-click on Add/Remove programs. Then reinstall these programs from the original source media. Option 6: If you are using Outlook 98/2000, please follow the steps in Chapura FAQ PM108 "How do I change Outlook from "Internet Only" to "Corporate/Workgroup" Mode?"
Sep 11, 2005 | Palm m125 Handheld
How do I NOT HotSync with Outlook?
Insert the installation CD and select Change your synchronization method. If that doesn't work, or the option is not available, in Windows, click Start>Run then D:\English\PostInstall\OutlookSwitcher.exe /palm (where D: is your CD drive AND your install CD is inserted; also check to make sure the file is at that location).
Sep 11, 2005 | Palm Zire 31 Handheld
Outlook on IBM T42
You never mentioned your drivers, they could be out of whack. Try updating them or get a Microsoft compatible driver. Check the device manager for problems.
Sep 11, 2005 | Palm m505 Handheld
How do I update my palm with outlook???
1. make sure Outlook is running on the PC 2. make sure hotsync is running - right click on the hotsync icon in the system tray - click custom - set all the things you "want" to sync and setup the way you want them (i.e. handheld over rides PC, they both sync, etc) 3. have VersaMail configured and setup as well...that's where your Outlook mail will come from 4. Push the hotsync button on your cable/cradle This should get you started. If I missed a step, it should be obvious in the Hotsync log, so check the log after doing a Hotsync.
Sep 07, 2005 | Palm Handspring Visor Platinum Handheld
Palm Vx Handheld Logo
56 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
