SOURCE: foxconn motherboard pinout
Please follow this link and download the manual.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002117
Don't be surprise that the manual name is 662M03, it is still the right manual becuase is made for both type of motherboards.
SOURCE: Foxcon Motherboard pinout
Hi bwalker24,
This is a pic of how to connect you're LED & switches.
Enjoy!
Mike
SOURCE: Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
SOURCE: I'd like to know the sequence to connect the
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
SOURCE: case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
