Question about Philips Magnavox 51MP392H Rear Projection Television
CONVERGENCE HOW TO ADJUST THE CONVERGENCE?
    Genius:
  • 1,139 Answers
Hello divine tagle,
On your TVs menu you should have a convergence adjustment section. Find this and given the age of your TV it should allow you to adjust what is called dynamic convergence which is the center of the screen and outward. It will do so by having you adjust the blue crosshair and the red crosshair until the completly overlap. The it will have you save the setting and this for the most part is how you can set the convergence on your TV set. These are just rule of thumb adjustment, you can find better detailed instructions in your users guide, (which is you do not have it can be found on-line, or at the manufactures site).
I hope this helps
Thank you,
Shuttle83
Posted on Sep 20, 2008
Rca projection tv mod:P52937SG
It seems like a convergence fault. Either the convergece cirlcuit, or the convergence settings have the fault To make it sure, try to adjust convergence adjustment. You have to enter its service mode option to do this. http://electronicshelponline.blogspot.com/ Check this link and pull up older posts. One among them have details about how to adjust convergence for projection television. If no effect can be seen during convergence adjust, make sure that the convergence board have the fault. You have to check further more into.
May 27, 2013 | Televison & Video
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
How do i make all the colors sync up to get rid of yellow and blue shadowing
Go into the customer menu with the remote and select convergence; if red or blue will not adjust in some direction you have a convergence circuit problem----depending on actual model number set uses two convergence chips--they would have to be replaced.
If the convergence does adjust in the customer menu but not good enough I can give you the sequence to get into the tech menu to fine adjust-remember if if will not adjust in the customer mode, it will not adjust in the tech mode either.
See attached photo of Philips convergence problem.
If this told you something you did not know, rate this solution as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Philips Televison & Video
Red convergence will not adjust
You need to have your convergence amplifers changed. May be some bad resistors as well. Should be no problem for professional
Apr 08, 2009 | Televison & Video
My screen has a wave in it/red convergence won't adjust
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence off
The convergence board is bad. If the convergence board were still good, then the convergence menu would allow you to adjust the crosshairs.
Mar 03, 2008 | Philips 51PW9303 51" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
