Question about Palm Tungsten E Handheld
HotSync Is there a setting to have the TungstenE hotsync periodically through the day instead of always doing it manually?
    Master:
  • 473 Answers
Try AutoSync or BackupBuddy Professional No, there is not a built-in setting that allows you to automatically HotSync throughout the day. But you can add it with extra software.
Posted on Sep 11, 2005
SOURCE:
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
I am using Windows 7 and want to Hotsync my 1000s of Memo Notes from My Palm Treo 650, I got the latest Palm Desktop and Hotsync Manager but My Computer cannot Hotsync or even detet my Treo 650....Pls...
Palm Desktop compatibility with Windows 7 and 64-bit editions Palm Desktop 6.2 was designed for 32-bit editions of Windows XP and Windows Vista. You may be able to use this software with other versions of Windows.
Windows 7: Many users have successfully installed and used Palm Desktop 6.2 with Windows 7. Palm has not done thorough testing with a range of third-party equipment running Windows 7, therefore Palm cannot guarantee compatibility.
64-bit editions of Windows: USB HotSync is not supported. Instead, synchronize through a Bluetooth wireless connection: set up Bluetooth HotSync.
http://kb.palm.com/wps/portal/kb/common/article/49229_en.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 18, 2010 | Palm Treo 650 Handheld
Palm centro trying to synch without being connected to PC
Hello brad_bork,
Make sure bluetooth is turned off and the usb cable is not connected. Then do the following:
•Tap the hotsync icon
•Notice the words 'Local | Modem' side by side on the screen
•Tap 'Modem'
•Select 'Standard Modem' in drop-down list
•Enter any phone number (eg. 800-525-6452 *this is a non-working number)
•Press the Home button
Now hotsync should stop trying to sync automatically. When you want to run a hotsync Tap on 'Local' in the hotsync screen.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 24, 2010 | Sprint Palm Centro Smartphone
Handspring Visor Username Deleted; How to Add on Device
To recreate your problem, I have setup the my Visor with no username, placed it in the cradle, and connected the cradle via USB port.
In this configuration, I do receive the same error message that you reported. Multiple issues can cause this error to be generated.
1. Place your Prism in the blue charging cradle. Confirm that the green charging LED is flashing or illuminated (below the power button on the Prism). If the green LED is not lit, then reposition the Prism until it is. If the green LED still doesn't illuminate then check the cradle and it's connectors for dirt and debris. Also check the copper connectors on the Prism for dirt and debris.
2. Depress the grey HotSync button on the charging cradle. The error message will appear. Press OK to clear the error display. If nothing happens when you press the grey button you need to check the copper connectors in the blue cradle and the bottom edge of the Prism for dirt and debris.
3. Check the upper right hand corner of the Prism display for the HotSync application. If any characters appear on the top line, opposite the HotSync header, then that is your username. If no characters are present, then there is no username in the PDA.
Regardless of whether there is a username in the Prism, the HotSync should still be possible. Once you successfully connect the cradle to the USB port and successfully connect to the desktop computer, a popup window will ask you to Create or Select the HotSync User.
Do you receive this popup window on the PC?
If not, your setup or connection probably has an issue.
4. Look at the Prism HotSync screen. Underneath the HotSync icon in the center of the display is a Drop Down selection. The options are
a. Direct USB/Serial
b. IR to a PC/Handheld
Since you are using the cradle, you should select option a.
Once you have confirmed this setup, you need to confirm the desktop computer setup.
5. Be sure to start the HotSync Manager Application on the desktop computer.
6. Left Click on the desktop computer HotSync Icon in the system tray, and confirm that Local USB has a checkmark beside it.
7. Depress the grey HotSync button on the charging cradle again. If the HotSync popup still does not appear on the desktop computer, left click on the HotSync icon and uncheck Local, Modem Network and Infrared and then depress the HotSync Button again.
There is a hidden method in the Prism for deleting the user name.
  • Open the Memo application on your Prism.
  • Tap New.
  • Enter the ShortCut character.
  • Enter a period '.'
  • Enter the number 5.
Whether you entered the shortcut character, period and 5 correctly or not, the characters you've entered will disappear and the memo pad will remain blank. To see if you succeeded:
  1. Depress the Grey HotSync button on the cradle
  2. Your user name appears in the upper right corner of the screen: if it's blank, then your user name has been deleted. The next time you HotSync with this device, you will be asked to create a new user name.
Note: Creating a new User name, will not affect the data stored in the Prism, other than initializing the user name.
There is a freeware application to Change the user name on the Prism, but you would need to HotSync to the desktop or beam the application from another Palm PDA to install it.
Jul 12, 2009 | Handspring Visor Prism Handheld
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
HotSync Problem!!
You have at least one application that is attempting a serial connection with the PC and is triggering hotsync instead. Many palm apps that allow live updating to your device when cradled or over blue-tooth can cause this type of error. I would take inventory of any software you added recently to your device or port settings you may have changed, especially regarding direct connect and cradle settings.
Sep 28, 2008 | Palm Treo 500 Centro
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
How do I update my palm with outlook???
1. make sure Outlook is running on the PC 2. make sure hotsync is running - right click on the hotsync icon in the system tray - click custom - set all the things you "want" to sync and setup the way you want them (i.e. handheld over rides PC, they both sync, etc) 3. have VersaMail configured and setup as well...that's where your Outlook mail will come from 4. Push the hotsync button on your cable/cradle This should get you started. If I missed a step, it should be obvious in the Hotsync log, so check the log after doing a Hotsync.
Sep 07, 2005 | Palm Handspring Visor Platinum Handheld
Palm Tungsten E Handheld Logo
41 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
