Question about U-Line Refrigerator Ice Maker
U-Line icemaker is undependable
I have a U-Line Bar Ice Maker/Refrig that makes ice very sporadically. Does anyone have a suggestion for the correct temp setting that would allow the ice/refrig to do both chores desired of ice making and keeping bevs cool without freezing them?
  • christy721 Aug 31, 2008
    Thank you so much for taking the time to help. I will give this a try. Thanks again.
  • 725 Answers
To make ice the thermo in the ice maker must be below 5 F...make sure there is a clear flow between the evaporator and the ice make also make sure you have a good seal between the freezer and the refrig areas..
1) put a cup of water in the refrig.
2)start with the coolest setting and move 1 setting every 24 hrs.
until it up until it freezing the water.
3) coolest you can get but not freezing the refrig...
hope is help
Posted on Aug 30, 2008
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not producing ice,already check the basic problems,
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
May 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker don't make ice
Pour about 2/3 cup of water into the ice maker . If it dumps the cubes but doesn't refill with water , replace the water inlet valve , behind refrig , where the water line connects to on the refrig .
If it does not dump the cubes , and the cubes stay in the ice maker , replace the icemaker .
Oct 13, 2009 | GE Refrigerators
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
Aug 30, 2009 | Whirlpool Refrigerators
My ice maker isn't making ice
the way the ice maker sits in the front of the freezer I personally think is not a good design.nice but not good.most every k.a. superba that had problem with icemaker that i have checked had a bad ice maker.replace the icemaker.but you may want to check all tubing connections from water valve to icemaker and make sure no break in line.most likely it is the ice maker.that ice maker is not a cheep one.good luck.
Mar 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
U-Line Refrigerator Ice Maker Logo
176 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
