Question about Insignia IS-LCDTV32 32 in. Television
IS-LCDTV32 32 Picture Blanks out but sound remains.
The picture on the unit cuts out shortly after turning it on. Turning the TV off and back on makes the picture return but it cuts outs after a minute or two. The power light stays blue and the screen still has power (dim glow visible in the dark the same as it does when it is onvidoe with no input) and the sound still functions.
  • 1 more comment
  • jdluna2000 Sep 01, 2008
    I have the same issue.
  • hellrell Sep 07, 2008
    changing the power cord.
  • Anonymous Mar 23, 2014
    Toshiba 32" 32XV505D TV no picture, however there is a glow from screen but only visible when in a dark environment
    President:
  • 1,263 Answers
The dm chip on the mother board has malfunctioned and needs replacing.
Posted on Aug 30, 2008
What is the dm chip and where can I get one online?
Posted on Sep 01, 2008
Sound and picture go out after about 3-4 minutes. Then com back on after a few seconds then go out again and not return. What can this be?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 27, 2015 | Samsung Televison & Video
Cuts off shortly after turning it on
Sounds like you have a short some place, and it needs to be replaced.
Dec 25, 2012 | Hamilton Beach 33966 6-Quart Slow Cooker
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
The picture blinks three times and then blanks out but the sound remains
This sounds like your monitor back light is not working. If you look really hard at the screen, can you see a very dim picture? If so the back light isn't working. This is almost always an inverter problem and can be fixed.
Jan 13, 2010 | Samsung (TN-RBNG10) TV Input
Tv turns off by itself after few seconds has been turned on
tv turning off automatically
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv power led comes but no picture comes up..in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not on the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
Dec 28, 2009 | Panasonic Televison & Video
My tv shuts off at random times and when I turn it on again the color is messed up.
Nov 16, 2009 | Olevia LT42HVi 42 in. LCD Television
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
201 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
