Question about Kenmore 53082 / 53084 Side by Side Refrigerator
Leaking water we have a side by side refridgerator, its leaking water BAD..... water is leaking from the water/ ice dispenser now its from the bottom of the fridge part too... how do i solve this problem or how do i disconnect the water...
  • sueboyd2 Sep 06, 2008
    water leaking from freezer side of frost free side by side GE
  • Kenmore Master
  • 528 Answers
Turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
Posted on Jan 03, 2010
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Model #ed22tqxvw00 problem: my water faucet in door was leaking when not being used so I turned off the water supply to the refridgerator but the faucet continues to leak drops of water. Where is the...
A couple things you need to check for your refrigerator water leak. First, if the water is actually leaking from the plastic tube for the water dispenser, and not from the flapping door that opens to allow ice to flow through door. If water is dripping from the flapping door, this could be ice melting, are you having any freezer temperature problems, is ice cream or bread soft ? If temperatures are fine, inspect the ice in the bucket, is it in clumps or one solid block of ice? If you have either this problem or the water is dripping from the plastic tube for the water dispenser, you likely have a problem with your water valve for either the ice maker or the water dispenser. Either way, both valves are part of one assembly, and both have to be replaced.
The other thing you need to check is that source water valve you shut off. Since there is no pump in a refrigerator, only those valves, the water that is leaking out of the fridge has to still be coming into the refrigerator. In other words, either that source valve is not shut off completely or it too is bad, or you shut the wrong source valve off, possibly for your house humidifier.
Nov 04, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Freezer & Refrig does not get cold
without a model number to check out what else might be in that area of the door i'd say a piece of tubing from the water source is leaking, or you are getting ice melt from inside somehow making it out through that panel now. i believe the water for the door comes in through the bottom of the freezer door and works its way up to the dispenser area, the solenoid for the water inlet is behind the fridge near the bottom (you'll see the water tubing).
more likely somethings just not fitted or aligned properly and waters making it out someplace it shouldn't.
best of luck to ya
May 27, 2010 | Frigidaire FRS26H7CS Side by Side...
Does not make ice, does not dispense water. Can
Sounds like the motor that controls the water flow is either broken or defective. Or the water valve is turned off.
Feb 03, 2010 | Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge leaking water supply off
The water is defrosted frost from the cold coils. Look for ice at the bottom of the freezer at the back wall. Carefully remove back panel. Most often the problem is that the drain hole to the pan underneath the fridge is blocked. and then it gets further blocked with ice as defrosted water cannot drain away. Clear carefully with a hairdryer, Clean drain hole with hot water and a turkey baster. Shoot water through to the pan below. If ice comes back in a few weeks you need to troubleshoot defrost heater circuit. Most common bad parts in order are defrost thermostat, defrost timer, fuses in defrost circuit which don't reset.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
I can't get water from my water dispenser
the water tank is probably frozen or the filter is totally blocked does the ice maker work? i take it its a french door bottom freezer? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Oct 01, 2007 | Jenn-Air JCD2295HES Side by Side...
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
155 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
