Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator not cold
Sometime this afternoon our Refrierator defrosted everthing in freezer. I found this problem when I went to get crushed ice from icemaker on the door of freezer and it poured water and went everywhere.I opened the freezer door and everything was defrosted. I opened the other side , refrigerator part and saw the computer numbers read like it was still working. The refrigerator running but not working.
  • 639 Answers
Friend,
ngfam1 At your service!
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
Ice maker only produces crushed ice no cubes
Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
Apr 16, 2016 | Frigidaire Refrigerators
Side by side refrierator leaks water
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
My refrigerator is not cold! It just stopped cooling this afternoon for no apparent reason. The freezer is fine. Any suggestions? It is a Kenmore Elite top over bottom.
ck the fan in freezer if it quits ( a very common problem ) then the fresh food area will get warmer . and tomorrow the freezer will start to fail . if not the fan ck for ice in back of freezer and if found you have a defrost problem also very common .. ****
Feb 23, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is not getting cold
fan motor running in freezer?- put unit in defrost the timer has a slotted set screw turn clockwise the unit will go into defrost the electric heater will start/ the fan in freezer and compressor will stop do a few times to get rid of ice if does not go into defrost a couple of things maybe wrong the first thing to check is fan motor in freezer should be running if not everthing will freeze
Jan 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
