Question about Fisher and Paykel GWL11 Top Load Washer
GW709 MACHINE SMART DRIVE LOAD 7.5
I HOPE YOU CAN HELP ... MY MACHINE WILL NOT START ON THE SPIN/RINSE CYCLE ... THE LIGHT DISPLAY IS AS FOLLOWS
1 2 3 4 5 6 7 8 OFF OFF ON ON ON ON ON OFF
WE HAVE CHECKED HOSES AND DISCHARGED PORTS
THE MACHINE SEEMS TO RUN IN THE WASH MODE BUT WILL NOT ACTUALLY SPIN IN THE RINSE/SPIN MODE ... ANY HELP WOULD BE APPRECIATED .. WE HAD A TECHNICIAN OUT APPROXIMATELY 2 MONTHS AGO WHO CHANGED THE AUTOMATED BALANCE MODULE IN THE CONTROL PANEL.   MANY THANKS JENNIFER TULLY
Hi All,
I've just had a similar problem with a GW709 Phase 5, in that it would not spin. It would pump out the water and then sit there with the pump running. It would do a inner bowl check and that is all. Finally it would time out and give a beep every 5 secs or so.
No "last faults" could be identifed in the diagonist mode 3
The problem turned out to be a blocked pressure sensor pipe.
Cheers,
L300van
Posted on Jan 29, 2013
  • 46 Answers
Hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Posted on Oct 02, 2008
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Fisher and Paykel GWL11 Top Load Washer Logo
290 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
