2008 Jeep Cherokee Grand Logo
Chad Beckett Posted on Jul 24, 2011
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1891
Points
11
Car won't Crank/start
With a voltage meter see how many volts are at the starter terminal. If not 12+ volts you have a bad connection. Check connection at the starter solenoid. Does it have 12+volts? Short the solenoid. Does it put voltage to the starter?
2008 Jeep Liberty
Possible solution - This happened to me and my battery was dead in my key fob and also I needed an ignition switch because a piece on it was broken which therefore wouldn't turn to start the engine.
2008 GMC Acadia radio won't turn on
The radio and BCM needs read for codes. No reason for the radio not to work after a FOB program. Just a guess, but if the battery power was to low, radio is locked out.
96 Jeep Cherokee WON'T start My daughter's 96 Jeep
did you replace the ECu with a used one or new. if it a used one did you match it to the old.why di you change the ECU.? when you turn the key in the start position does the fuel pump turn on? does it crank? do you know if there is spark if you pull one spark plug wire?
1helpful
2008 jeep grand cherokee won't start
sounds like maybe you need a starter... if you take it out you can take it to any auto parts store and they can test it for free.
Jeep stalls gauges don't work windows and locks and radio don't work
when you state it wouldn't crank, do you mean the starter won't engage or that it just spins over and doesn't start? if no gauges or no starter engagement, then check the battery, battery connections,and the starter for excessive amperage draw. if the starter spins and the engine won't start, then check crankshaft position sensor first. the crank sensor is a more common failure than the distributor or any of the other things you mentioned.
I can't start my 2008 Jeep Grand Cherokee with either key fob. Once I got a "Service Security Key" message. Another time I got the "Key not programmed - Damaged key" message. What...
Hi Hal,
Did you ever get this resolved? Looks like you didn't get any feedback here! I'm having the same issue sporadically. I turn the key and nothing. Usually if I keep trying it will eventually start cranking and start. Usually within 10 - 15 tries. happened last night. After it started, I got the "Service Security Key" message. I looked in the manual and it does say what that means. Don't know if it is programming (probably not because the fob works 97% of teh time) or maybe just a dying battery. If you can share anything you might have founf out I'd appreciate it! thanks!
Brian
3answers
My 1998 jeep cheorkee engine turns but won't crank, could it be the computer or what?
it's highly unlikely, there are only two things that can make this happen, not getting fuel (fuel pump failure, fuel pump regulator) or not getting ignition (bad coils, ignition module failure, bad distributor, distributor cap, rotor)
2answers
Have a 2008 jeep grand cherokee laredo put key in ignition and dash board says damaged key and another service security key jeep wont start
This sounds like a bad chip in the key, try a spare key, if it starts with spare key then key is bad, if it doesnt start then you will need reprograming
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
