Not switching on
Gigabyte 815G Motherboard
motherboard not getting switching on, Power god signal not coming to SMPS.
SMPS checked and found serviceable.
even tried with other serviceable SMPS
tried by removing CMOS battery and other all accessories also
even the LED on m/b not gtg on.
  • chanderson12 Aug 31, 2008
    Mother board not powering up no beep nothing , but the power supply fan runs. not so bright at this but if someone can instruct I can follow.
  • 3 Answers
Wrong or bad cpu
Posted on Sep 01, 2008
I Have An IBM x3400 How do i test the smps using a voltometer
Since you haven't mentioned the type of server its unsure server has single type or dual type SMPS. This issue can due to SMPS as well Plannar (motherboard) issue. But as per post i really doubt you have bad motherboard since you see BMC and other LEDS on motherboard gets blinking..
You can troubleshoot motherboard issue this way. Press and hold server power button. Check if this makes server start. If it starts, then its confirmed you have bad motherboard.. You may also inspect whether motherboard has bulged capacitors inside..
Thanks
Oct 05, 2012 | IBM x3400 Server
WHAT IS THE CAPACITY OF SMPS
Hello Mkmanishbit2 hi, SMPS means switch mode power supply. The capacity of an SMPS unit is from 200 watts to 1500 watts, and some can be 2000 watts. Now for your Gigabyte Motherboard, a standard 350 watts unit will do, for medium end gaming, 500 watts will be enough, and for high end gaming, use the 800 to 1500 watts unit. Reminder the higher the watts number the higher the price, but the safer it becomes.
Nov 30, 2010 | Intel Motherboard
Hello Sir, When SMPS for motherboard burnt, all LEDs of Keyboard and CPU were constantly glown but system switched off. PC not getting on even after replacement of SMPS. When checked input power supply,...
Get a good used mo bo on ebay to replace the one you have.
Make sure you get the exact replacement and it will go right in and you will not have any hassles with compatibility/driver issues.
Lot cheaper!!!!!!!!!!!!!!!!
Mar 21, 2017 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
While switching on pc the smps become u/s. I changed to new smps, now the mainboard is getting power but pc is not getting on.
check the 4 pin power supply for display coming from the SMPS which should connect to the slot near the processer
Aug 08, 2010 | Intel D945GTP Motherboard
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
My computer has no display or beeps whatsoever after i push the power button. the CPU fan is running as well as the LED indicator.what possibly is wrong with my motherboard or cpu
you need to do many task for this simple prob:-)
>> take out the RAM and switch on the system even thought if you don't get beep then
>>>> take out the Bios battery and switch on , if here also you don't get
>>>> check the SMPS
>>>check the processor with some other board where your processor support
>>>> check your m/board with some other processor which your board support
Feb 23, 2010 | Gigabyte GA-G31M-ES2L Motherboard
I have a D946GZIS motherboard. It does not boot whenever i switch it on and press the power button. Also the power led is not glowing. What must be the problem..? pls help ..
Starting at the begining. The wall socket, the plug, the cable, the power socket on the SMPS at the back of your PC, the SMPS, the Output connectors from the SMPS to the motherboard. The power LED not glowing means that the power is not reaching the motherboard. Disconnect and reconnect the power connector on the motherboard. start. No start. Does the fan on the SMPS work? If yes then all components before the SMPS are doing fine. If no then most likely connection socket power cable to the SMPS may be the culprit. This has a lot of load on it. The PC and the monitor both take power from this socket. the answer to your problem lies in the answer to my question whether the fan starts in the SMPS or not. If yes then there is no output from the SMPS and the SMPS need to be given the due attention and if no then there is no power input to the SMPS and various cables and socketc need that attention. In case you need to and can remove and open the SMPS look for bulged or burst capacitors. If found, replace them. Those round cylindrical components.
Nov 27, 2009 | Intel D946GZIS Motherboard
Gigabyte GA-8LD533 Motherboard driver not found
plz check the following website
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1402
Jun 13, 2008 | Gigabyte GA-8LD533 Motherboard
Gigabyte GA-7N400 Pro2
hi
clear your bios setup with jumper settings.
or
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Computers & Internet Logo
451 people viewed this question
David Payne
David Payne
