Question about Photography
Pentax lens difficult to remove from Super Program /Super A camera
Gotten off with difficulty after 'jiggling. From about half engaged when mounting rotation is very stiff.
On one of the rings behind the mount, at about 2 o'clock there is a rectangular vertical tab that at its base is secured to a ring by two tiny rivets. This tab is not perpendicular to its mount, being angled back about fifteen degrees anticlockwise facing the camera, and slightly lifted. There is evidence of rubbing on the top of this tab. I think that a previous owner had a go at dismantling the mount as one of the mounting screws shows rubbing, indicating that it was not seated below the level of the mount face. However that is not now the case.
This tab now appears to have been the problem. Using needle nosed pliers, I very carefully realigned the tab at 90 degrees to the mount face with the top lying adjacent to the inner edge of the mount, at the same time ensuring that the top of the tab did not protrude beyond the mount face.
Having done this, I mounted and removed the lens several times without impediment. The last half of rotation of the lens when mounting remains quite tight, but I do not know if this is normal or otherwise for a 50mm f1.4 SMC A. The mounting and lens lugs show virtually no sign of wear so probably retain as-new tolerances.
I hope this helps anyone who may have a mount with a misaligned tab. Although I have an electronic copy of the Super Program/Super A parts breakdown, I have been unable to identify the tab or a part number, probably because it is an integral part of its mounting and the document copy is not sharply rendered.
Cheers
Malcolm
Posted on Aug 31, 2008
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
How to reassemble 50 mm pentax slr lens
The problem usually comes about when the focussing ring comes loose. Step 1 remove the 1.front round name ring 2. filter ring. this will expose three screws that hole the focus ring in place. reset the focussing to infinity on your viewfinder then set the ring to the infinity mark and retighten. If the helicoid has come apart then take the mount ring out, aperture ring out, and remove the two focus guides. turn the core out, set the fine thread back until it is almost against the ring directly behind it. make sure that it has at least one and one half turns. then engage the helicoid back. refit the focussing core into the lens and refit the two guides.reassemble the lens and revert to step one to reset the lens.
Oct 05, 2013 | Pentax K1000 35mm SLR Camera
I would like to use my Sigma 600 Mirror lense on Nikon M80 digital camara body lense was used on a Pentax Super A camara before can it fit
Sorry, no. If it fit onto a Pentax camera then the lens has a Pentax mount. The Nikon (I assume you mean the D80 digital camera, or perhaps the N80 film camera) has a Nikon mount. Since the Nikon mount has a deeper flange distance than the Pentax mount, there are no adapters available to allow you to fit a Pentax-mount lens onto a Nikon camera.
Jan 14, 2013 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
Nov 24, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I have a sigma 600mm k mount lens that I would like to use on a nikon 3100, is there a adapter available?
No. The Nikon F mount has a longer flange focal length than the Pentax K. What this means is that a lens adapter to fit a K mount lens onto a F mount body would have to have a negative thickness, which is a bit difficult to build with current technology.
Adapters going the other way are possible and available.
Feb 16, 2012 | Sigma Super Telephoto 600mm f/8.0 Mirror...
I own a Tamron SP 80-210 adaptall II len with Pentax mount. I currently own a Nikon 7000. Can I use the Tamron with the Nikon by adding a adaptor? Any suggested adaptor I should be using? Thanks
Hi, The focal distance on Pentax camera's is different then the focal distance on Nikon's so because of that Pentax lens' can't be adapted to work on a Nikon camera. I'd suggest finding a similar lens with a Nikon mount as cross brand mounting is quite difficult.
Sep 09, 2011 | Nikon D7000 Digital Camera
I HAVE AN OLD PENTAX ME SUPER 35MM CAMERA AND HAVE BEEN GIVEN A HANIMEX AUTO ZOOM F/80-200MM LENS BUT NEED AN ADAPTER RING TO FIT BOTH TOGETHER.COULD YOU PLEASE TELL ME WHICH ADAPTER I NEED AND IF POSS...
You don't need an adapter ring, you simply need the correct lens. Like many aftermarket lenses, the Hanimex was made in a number of different versions to fit many different camera mounting systems.
Your camera accepts lenses with a Pentax K bayonet mounting, so the fix is to sell your lens (it's not worth very much though) and buy another which also shouldn't cost very much. You can even get them for free simply by asking on FreeCycle, it's where virtually all of my film camera equipment has come from.
It *might* be possible to get an adapter, but it depends entirely upon which mount the Hanimex currently has (you didn't say, and it's not always obvious just by looking at the lens), and very few can be adapted to a K mount. Those that do will lose automatic aperture coupling, making the lens and camera rather awkward to use, and the coupling will likely cost more than another similar lens in the same zoom range.
Aug 04, 2011 | Pentax ME Super 35mm SLR Camera
Does Sigma 70-300mm works on Canon EOS 350D?
Sigma makes lenses with a variety of camera mounts. A lens with a Pentax mount, for example, will not fit onto a Canon camera. Assuming you get the lens with the Canon mount, then it will work on the EOS 350D with full functionality.
Feb 16, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
What does smcp -fa mean
SMCP- means: Super MultiCoated Pentax (a term that refers to the anti-relctive coatings that Pentax has been using on its lenses for years F-means it is a lens designed to cover the larger area required of a lens for Film camera use versus the smaller sensor of the Digital SLRs Pentax also makes. Pentax also makes DA lenses , which will only work with their digital SLRs. A- means it will work in fully automatic mode on cameras that have the ability to set shutter speed and F-stop automatically (most modern Pentaxes) It should also be noted that all DA and FA pentax lenses have a modified version of the original Pentax K lens mount, which replaced their first lens mount, the universal M42 used by so many early film SLR manufacurers- this concluded todays pentax lens history
Jun 02, 2010 | Pentax Zoom Wide Angle SMCP-FA 28-105mm...
Can lens assemblies normally used with Pentax 35 MM cameras be used with Pentax digital cameras? My 35 MM camera is a Program Plus.
not realy,,, the digital camera is tottely difrent
anyhow they would all be supper long lenses,,,
Oct 14, 2009 | Cameras
Photography Logo
61 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
