Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca 52 inch hdtv turns itself off after a few minutes
We turn the tv on and then within a few minutes, it is back off, we have had 2 services guys come out and try to fix it, and this has cost us 300.00 so far, the tv is just over 1 year old, I bought Rca because of the name, now I am extremely dissatisfied, I expected it to last a little bit longer for the price I paid, Now the image goes to a green and then off, sometimes we just get sound for a few minutes. Can anyone help me.
  • 2 more comments
  • snshine_hunn Aug 30, 2008
    My problem is that when you turn the TV on there is a loud humming noise. I have had the cable company come out and there is nothing wrong with the line. the sound is coming from the TV.I have had the tv serviced and they ar indicating that its some type of sound board that can only be purchased overseas and that is going to take about 8-12 weeks maybe longer because this part is only made once a year...... Please assist
  • Ajeremiah Sep 07, 2008
    We are having the same problem. the tv turns off by itself and then back on. We had this tv about a year.
  • Jeannie1154 Oct 03, 2008
    I will have the repair man out one last time to try this solution thank you for some direction. Do you know if RCA will do anything about this problem being the TV is so new? Please respond to me at
    We are in need of it fixed as my husband is going thru chemo and really needs to have something to keep his mind busy.
    Thanks again
  • decoleonly Oct 11, 2008
    I have the same problem. My tv was in storage for 3 months. It worked fine before it went to storage. We got everything unpacked and when we turned on the tv it turned itself off after about 5-6 seconds. I eventually got it to work that night after turning it off and on multiple times. The next day it would just turn itself off after 5-6 seconds. It has not worked again. What is wrong with it?
    Problem Solver:
  • 39 Answers
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Posted on Oct 02, 2008
  • 800pctechs
    800pctechs Oct 03, 2008
    Make sure ahead of time that they have a picture tube analyser/restorer. Thats really key here.
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv will not stay on
Check your power outlet for problems with hot/neutral/ground. If the outlet is good your TV is telling you it needs to be looked at by a service tech.
Jan 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52 inch was doing the same thing.  TV guy had me use a regular hair blower blowing very hot on the power supply board ( bottom left in back). After a few minutes the tv would come on.  He replaced 2 capacitors, charged me $100.00, plus the $95.00 service call, and is working fine now.  This was a month ago.  So far so good.  He only took the board to the shop, not the entire tv.  Hope this helps.
Oct 04, 2007 | RCA HD52W56 52" Rear Projection HDTV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,055 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
