Question about Olympus FE-210 Digital Camera
Olympus fe-210 screen probloms
When I turn on my camera all i get is a gray lined screen. The lens comes out and it flashes when I press the button, but no image. Its almost a new camera, though a year old.
  • pegmail Sep 06, 2008
    After taking a picture the display goes black. I have tried resetting the power and replacing the batteries but get the same result.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Try the power reset by pressing the power button for about 10 seconds with batteries out... if this does not work then repair
Posted on Sep 05, 2008
Lens wont go in power button wont lite or come on and screen display nothing what is happen to my fe 210 olympus camera
I have the same camera! But my display is broken. :( But it still works. Try plugging in the external video cable to see if you can see the display on your TV.
Make sure the battery is fully charged. If the battery is no longer holding a charge, replace it or use the appropriate AC adapter to power the camera.
Also, remove the memory card if you are using one in you camera.
After you put a freshly charged battery in or plug in the AC adapter, press and hold the power button for at least 3 full seconds. The lens should extend fully. If it doesn't, press the playback [>] button on the back (this should make the lens retract). Then press the power button to shut the camera off. Press the power button again to power it back up and the lens should extend out as normal. You should be OK.
If not, let me know and I'll see what else I can dig up.
The last thing you can try is updating the Firmware. Below is a link to the Firmware update for this camera. Since I don't know what OS you're using, just pick your Operating System and follow the instructions on the pages that follow the link you chose.
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1300
Dec 04, 2010 | Olympus FE-210 Digital Camera
My screen is completely white with blue lines.
You might have bumped the LCD screen, they break really easily. You can replace it yourself by ordering one on Ebay for about $25.00. A repair shop quoted me $125, but I would buy a new one in that case. It's not hard to change one, but you have to be careful, and make sure you discharge the flash capacitor. If you google the problem mentioning the make, model no., and add "changing LCD screen" you will find a lot of articles on it. Good luck, and maybe get a hard case for your next camera.
Mar 19, 2010 | Olympus FE-210 Digital Camera
Olympus FE-210 White LCD screen
Sounds as if this is a repair issue with the image processing chip inside the camera. You may want to call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 11, 2008 | Olympus FE-210 Digital Camera
Olympus FE 210, not turning on
clean the battery compartment and check the door for debris such as hair or sand
Nov 25, 2008 | Olympus FE-210 Digital Camera
My camera won't turn on!
Send to the Olympus repair center
Aug 17, 2008 | Olympus FE-210 Digital Camera
Olympus FE-210 lens does not come out
Hey memiche,
You could try resetting the camera to the default factory settings, and directions on how to do this are on page 20 of your camera manual. If this doesn't work then there is either something obstructing the movement of the lens (i.e. sand), or damage to the lens mechanism. If it is something obstructing the movement of the lens you could try blowing compressed air into the side of the lens to try and dislodge whatever is in there. If that doesn't fix the problem you could try putting the camera on a flat surface with the lens pointing up and holding in the shutter button, and while doing that turn the camera on. If none of this works I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jun 30, 2008 | Olympus FE-210 Digital Camera
Olympus FE-210
Hey dramaqueen79,
It sounds like you have internal damage to the camera. I would have it looked at be an authorized service center. If you are fine with the performance of the camera and all you want to do is be able to upload your images you could purchase a card reader(for an xd memory card) that connects to a usb port, and upload your images directly to your computer with the card reader.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 24, 2008 | Olympus FE-210 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
Olympus FE-210 Digital Camera Logo
120 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
