Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
17-85MM IS - mechanically stuck at 17mm - will not zoom -
Hello - My EFS17-85 IS USM has zoom ring stuck at 17mm setting.
I can move the zoom ring a little bit only - say about 2mm of travel.
On camera, lens focuses in manual and auto, and IS seems to work also.
Nothing rattles. No loose parts, it seems.
It definitely feels like some sort of mechanical problem, and I am comfortable taking gadgets apart, but I need guidance. The fee from Canon is a little hard to choke down.
I really appreciate any assistance.
Best Regards,
ed.m@lasermotion.com
  • 3 more comments
  • aralani Sep 05, 2008
    I have the same issue--stuck at 17mm. I don't mind taking it apart, but I don't want to turn a $100 fix bill into a new lens bill. Any help would be appreciated!
  • wobra Oct 02, 2008
    I have the same problem an no solution now. I opened the lens myself but without a result.
  • niels_orskov Nov 01, 2008
    Hi I have the same problem - It started during my vacation in Peru - where I really needed the camera. Canon in Lima ficed it, but now, I am home, it is stuck again.
    Is this a general problem with this lens??
    Basically i expext a robust quality from Canon - that doesent let me down, when I need it.
    I used to have a Nikon F - a very robust thing. I whish for something like that
  • Anonymous Nov 03, 2008
    I have the same problem I have taken it apart, took some time to get the connector out of the top ring, the black center piece have to come out first, then connector "falls" out, and the rest is just traigt forward, taking it apart bit by bit, but I havent been able to disasamble the zoom ring, have to let it rest for a few days before i give it a go again.
    Mr Andersson
  • martalongopr Nov 08, 2008
    Same problem you all have!!! New 17 - 85mm EFS and mechanically stuck at 17. I thought the kids may have done something to it, but it looks like it's a design glitch. Please help. I guess the warantee should cover this, but holidays are coming up and I don't want to send the camera in.
Hi all,
I've had the same problem. So I decided to give it a try because I didn't find any solutions on the net. Unfortunately you have to pay pretty much for a Canon lens while the internal quality is pretty cheap, the whole mechanism is of plastic and this is also the problem. And after a while some screws will vibrate loose from the plastic components and canon could have done this better.
Probably within your lens is now one of the three zoom mechanism screws complete removed and you will notice that there is some abnormal movement in the zoom part. Unfortunately these screws are deeply mounted inside the lens and you need a lots of skill and patience to get it fixed.
First you need to completely disassemble the lens, and please make a picture of your lens after every step you make because I had to disassemble my lens 4 times! Because some of the elements was not right in place.
I will try to place a more complete description later today including some pictures.
Regards Gert
Posted on Dec 04, 2008
  • 4 more comments
  • Gertus Dec 04, 2008
    Hi all,
    I wanted to edit my unfinished answer above but unfortunately I’m not able to edit my own solution. I asked the support of FixYa to remove it. But I’m also not able to post a complete manual on the crappy website because I’m exceeding the message limit. But I really would like to inform you that there is a possibility to fix it your self.
    So I’ve written a manual and posted it on a free file share website.
    This is the issue with the stuck of the zoom ring: The Canon lens is an expensive lens but build with cheap plastic materials. And due to the frequently use of the zoom mechanism the screws will become loose from the plastiic and at a certain moment the screw will completely be removed out of its position and will stuck somewhere in the lens. This causes that your zoom will lock.
    To solve this you will have to completely disassemble the lens which is pretty hard because the real zoom mechanism is deeply inside the lens.
    With the link below you can download my solution. Hopefully you’re also able to fix the lens.
    Best Regards
    Gert Jan,
    Link : Repairmanual Canon 17-85mm zoomlens
    Picture where the screw is missing
    Parts to be removed
    I would advise you to make good close-up pictures of every step you make. Because I had to
    disassemble my lens 3 times! Because I didn’t know the right position for some elements mostly in
    the focus ring. But I think you could leave the three metal rings from the focus area in place, this
    will save you a lot of precious work and time.
    Also use a screwdriver which exactly fits, otherwise you’ll damage the screwheads.
    For the steps below see the numbered image at the bottom of this document
    • Remove the aluminium ring at the back, (1)
    • Remove the two little screws in the connector
    • Tilt the ring a little and push with your thumb the black plastic inner part from inside to outside (2)
    • Remove the plastic housing and while removing use a little screwdriver to remove the cable rom the print (3)
    • Remove the cables from the print, one screw, and remove the print (4)
    • Remove the plastic part (5)
    • Remove the focus ring (6) but you probably can leave the metal rings in place (6a)
    • Remove the ring sticker at the front (7)
    • Remove the three screws and the front lens (8)
    • Use a little screwdriver to remove the rubber zoom band (9)
    • Remove the three screws inside the zoom unit (10)
    • Remove the three screws/rings at the side of the second zoom part (11)
    • Now you should be able to take out the inner lens-unit (12)
    Hopefully you’ll have the same problem and is there only a screw missing in the zoom-part. Return
    the screw at the original position and use loctite or something like nail polish to prevent the
    problem for the future. Now put everything back in the reverse order.
  • longy77 Aug 20, 2011
    Hey Gertus. great manual on fixing the zoom problem. I have a 17-55 f2.8 IS USM Canon Lens that I dropped and the zoom ring would zoom out but not in. I followed your manual to take the lens apart and even tho they are not the same it helped a lot. The only thing I didnt read was your do's and donts and I have removed the focus ring. Now I put it back together and the focus doesn't work. Did you have a similar problem and if so what did you do to fix it.??? Any help would be great. Cheers Bud.
    All sorted. I read a little further and found out I didnt have the clip in place when I reinstalled. If anyone knows of a site to pick up parts for canon lens please let me know. cheers
  • Papparazzi
    Papparazzi Oct 25, 2013
    Hoping that this will work...... there is a great place near by....... but they must be busy...... I thougth that I would attempt myself.. trying to fid the 3 d specs for dissambly on line.. nothing. I will youtube it, just in case it is successful..
    Problem Solver:
  • 6 Answers
I have just followed Gertus' instructions, it worked great! Some additional points:
- "print" = printed circuit board.
- There is a third screw attached to part (1) : it stops the lens from swinging around too far when attached to your camera body. I lost it - oops!
- Part (2) has four clips inside that hold it in place, I broke one off but things still hold.
- I concur with the comments on parts (6a) : they do not need to be removed.
- To remove part (12) there are three screws on the back, there are about 10 different ways you can reattach them, so TAKE A PHOTO!
- When reassembling make sure you feed the two ribbon cables from the zoom mechanism (12) through the main lens body - I forgot the first time and had to pull it apart and try again.
- When putting the zoom mechanism back in place, be very careful of the delicite wipers that slide along the small PCB - these are sensors for the focal length (captured in EXIF headers)
- When placing the zoom mechanism (12) back inside the main lens body a black plastic tab needs to run between two silver metal guides. If you do not, the lens will go back together but the focus will be WAY off.
Marcus
Posted on Feb 22, 2010
  • Papparazzi
    I am attempting this tomorrow......... think that I will Youtuve it..... just in case it is successful..
Check out this website for a step by step breakdown of how to fix it.
http://thydzik.com/canon-efs-17-85mm-is-stucklocked-zoom-repairdisassembly/
Posted on Dec 21, 2012
My Canon 17-85 IS F/4-5.6 IS USM zoom ring locked at 17mm. Any ideas how to fix it?
The most likely cause for this is faulty zoom guides within the lens. This will require complete disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 14, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom ring stuck at 17mm.
This is most likely caused by one of the assemblies comming loose inside the lens. This will require disassembly to repair and reseal. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Aug 08, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon 17-85 IS zoom ring locked at 17mm.
Sometimes, if that lens has heavy use or if it has been traveled with a lot, several of the internal zoom screws may come loose deep inside the lens and cause the zoom to freeze. It requires a complete disassembly of the lens to reach the screws and re-seal them so it does not happen again.
Bob Kilbourn www.camerarepairs.com
MY CANON EF 100-400MM USM LENS WON'T ZOOM PAST 150MM
Is the lens tension adjusting ring too tight? Try loosening it and see if you get increased travel. If so, you may need to have it checked out.
Feb 05, 2011 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
Zoon function stuck at 17mm
foreign /broken piece /screw etcmight have struk in the guide and between guide-pins.
Mar 07, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Stuck zoom too!
I had the same problem, but it was a case of getting a loose screw tightened up inside the lens.
I took it to an authorised dealer and it cost me the equivalent of about US$25 to get repaired, with the obvious advantage of not messing with the warrenty.
I also hadn't bumped my lens, and I only bought it in July, 2009.. so effectively, new. I did notice the zoom getting looser with time, and would fall out of the chosen zoom length when pointing down (and indeed, up).
Sep 30, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Jul 05, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Unsure of how to use the extra functionality
That is the focusing ring. I'm guessing your camera is set to focus automatically (Little switch on the side of the lens should have settings for either AF or MF, or something similar.)
If its on AF, you don't need to adjust the focus ring.
However, if you have problems with the AF (sometimes it has trouble, especially in low light) you can switch it to MF, and focus manually by changing the ring.
As a general guideline, the more you twist to towards macro, it focuses closer and closer, and infinity futher away (if you're taking a shot of the moon, you want it on infinity)
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
13,800 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
