I have a 19" Audiosonic LCD TV with DVD player model no. KM1902DVD. It has an analog tuner. I have plugged it in to the home TV arial and followed the prompts for autotune. The channels are snowy and unwatchable. What am I missing or doing wrog? Thanks, Janet.
I have a audiosonic brand digital tv, i just bought it 2 weeks ago, every time i turn it on, it plays sometime then goes to no signal, plus the picture messes up, or freezes, please help, what can i do too fix this, thank you!
Posted on Jan 19, 2013
ctf1800
  • 4402 Answers
SOURCE: No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Posted on Jan 31, 2008
  • 3 Answers
SOURCE: AKAI Wide Screen LCD TV/DVD Player Combo.#LCT3201AD
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
rongxin
  • 57 Answers
SOURCE: Just bought a Audiosonic KM2201DVD
Is there no factory setting on that unit sir,in that case the bad dics error is need to repair or fix some a technician.there are 3 different type or deffective parts to replace it.first type the MODULE of the dvd player ,is need to re-heat the parts of the module by using a hot-air or soldering iron,second loose connector or cable between the module and lens, and third look the lens if lights up while loading the dics which means the lens is good,if theres no lights up or lazer,the lens are deffective.
kira_ryuk99@yahoo.com
Technician
  • 9 Answers
SOURCE: I have just bought a
! When you tuned tv did you save it? 2 do you have analogue & freeview on your set? maybe you've hit the freeview button.
Posted on Mar 10, 2009
SOURCE: Olevia 537H digital tuner problem
I have the exact same problem with same symptoms. It was purchased from Target during their Black Friday sale in December, 2006. In 2007 I had the mainboard replaced under in home warranty to correct the static electricity pop that many people experienced. Then in early 2009 the digital tuner not working problem started. At first I could power off the set completely and upon repowering up it would work again for a while, but for the last few months nothing would get it working again, and yes I tried the "Bright Room" suggested elsewhere. I purchased a DVD recorder with a builtin NTSC/ATSC/Qam tuner (Panasonic DmR-EZ28) for $230 and hooked it up via the Composite jacks (HDMI would work also) and all now works, although the channel up/down function is quite slow. I was under the impression that the 537H came with a 3yr warranty (1 yr in home, 2 additional years parts) but when I contacted tech support to get a new mainboard sent out, discovered that the original Syntax Brillian company went bankrupt and service is now being handled by a company who says only 1 year warranty on all Olevia HDTVs. Replacement by them in your home is $318 and only a 90 day warranty on the service. Only other option that I can think of is use a cable or directTV settop box interface and connect it via HDMI.
If anyone can find the original warranty with the 1yr/3yr wording, I'd try going back to the retailer and get them to stand by that and send out a new main board, else if the cable or satelite settop box won't work for you keep looking for a remote tuner similar to the panasonic's functions without the dvd recording if you don't want that. Some of the new converter boxes that are almost free with the $40 government cuopons might work if they have the composite as well as the rf output, but will only detect ATSC not QAM and you'd have to experiment with getting the proper aspect ratio using the Olevia's remote's Aspect control.
Posted on Jul 10, 2009
I have a jensen Je 1911 dvdc, it will not stay on but 8 seconds help we have 8 days left
Jensen 19" 12-Volt TV/DVD - Camping World
www.campingworld.com > ... > TVs & Accessories > TVs
Rating: 2 - β€Ž2 votes - β€Ž$269.00 - β€ŽIn stock
Where does one get a replacement remote for the 19 inch /dvd model ??/. 1 answer(s)... Need remote replacement for Jensen JE1911ABC. 1 answer(s).
JENSEN LCD TV Accessories - Jensen RV Direct
www.jensenrvdirect.com > Products > LCD TVs
Items 1 - 12 of 22 - We also offer video control centers, PAL tuners, and digital tuner boxes which will convert your analog TV signal into a digital one.
postheadericon JENSEN JE1914DVDC DVD STAND
dynastre.tk/469748/dvd-jensen-je1914dvdc-stand
Dec 27, 2015 | Jensen Televison & Video
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Analog to Digital converter
Ur tv a LCD or Plasma tv?No,LCD and Plasma Tvs have a Digital tuner inside the tv to recieve free air DTV.Not require a Digital coverter box,if u have a LCD tv or a Plasma tv.U must have good antena thought like a roof or a digital antena,so ur tv picture don't cut in and out very often.
May 29, 2010 | Olevia 332V LCD TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Hi friend, My SONY VGC-LV250 only analog tuner can get signal,digital tuner does not work at all. Is there some setting wrong? I try my indoor antenna already. it works on other HDTV pretty well.
The signal strength needed for digital tv is slightly great for terestrial TV I assume the HDTV you are talking about is a player. First you need to test the unit on a known good arial if this works ok then you have two options get a better internal arial or get an external arial. The other option is to get an signal amplifier for the arial you have but there is still no guarrantee. Best option is a Digital arial the are designed to give the best signal strength thus picture.
Hope this Helps.
Dec 24, 2009 | Sony VGC-LV250J/B PC Desktop
Since they switched to digital TV, my VCR/DVD player will not record a TV program.
The DR-MV150B has both a digital tuner and analog tuner. Since the digital conversion you more likely have not run a channel scan for the new digital channels. Plugging in a digital tuner would work, but is unnecessary. What you probably have to do is run the 'auto scan' feature through the recorders menu. Hit "Home" button go to the "TV" icon and select "Auto Scan". It will take a few minutes, but recorder will scan for digital channels and memorize them.
Aug 13, 2009 | JVC DR-MV150B DVD Recorder/VCR
Digital tuner???
This contains an analog tuner IC only.
Jun 16, 2009 | TruTech PVS12701 Portable DVD Player
I have a DYNEX DX-R20TR, is this tv digital ready?
Hi dlcase777,
Good news, your TV has both Digital and analog tuners. You will only need an antenna to recieve digital OTA (over the air) signals.
I have provided a link for information on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Thank you for the oppurtunity to help and please rate this solution as a FixYa.
Lone99star
Jan 31, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
