I have just installed a Teac SDB451 set top box for a friend and I have installed antenna to it then used the video and audio outs to their vcr and vcr to their TV. I can get a picture using the set top box via the vcr but I can not set it up so we can watch one thing and tape another as the VCR & TV recievers dont appear to be getting the antenna signal from the set top box.
  • rayandjess Sep 14, 2008
    i have a teac sdb451 receiver and i can only get channel 9 and sbs and my 20 dollar speical from cash converters works better and its a no name brand can somone help me out
  • maffy24 Sep 25, 2008
    I also can only get about 2-3 channels. The channels sometimes change if the STB is moved. Does this model somehow get interference from other items such as wireless internet?
    Channel 10, SBS are always working and 9/7/ABC alternate. If anyone has a solution, please advise.
Go to http://vk3khb.gak.net.au/atv/chnlchrt.html#TV_Table
I went there and checked the details vs those appearing on my STB. Went through the manual channel search and changed the frequency to those on the above website. Now all channels work perfectly. I only bought this STB because my last one froze, it appears this one doesn't have the best auto search facility but with a bit of tinkering it will work for you!
Posted on Sep 25, 2008
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
How do i hook up my new cable box for descrambling to my vcr
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
Jul 28, 2017 | Symphonic SL260A S-VHS VCR
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Connet Hd set top box
May 31, 2009
Born to Race,
I have just bought a TEAC HBD841 which was on discounted sale at a local Electrical Store
Besides not being able to figure out how to connect the device to my elderly TV because the inadequate instruction booklet that is written in a language an Electrical Engineer would have difficulty understanding - does not explain which plugs go where, (try plugging a three plug lead into a 2 plug TV) but since then I have found out that the HDB841 has been withdrawn from sale and is no longer available.
No wonder it was cheap!
I suggest you get rid of it - quick
GB
Apr 20, 2009 | Televison & Video
I am trying to connect the vcr to the tv with a cable box
There are two ways to connect your equipment.
1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
Mar 30, 2009 | Hitachi Televison & Video
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
I still use my VCR to tape my favorite shows. How would that wor
what regular channels don't you get ?
to get the vcr to record the box you will need to either plug the box audio / video output jacks into the vcr audio / video input and antenna to tv OR plug RF antenna out of box to antenna in on the vcr and vcr antenna out to tv( or the video/audio out jacks on vcr to tv )
Jan 19, 2009 | Insignia Digital-to-Analog Converter for...
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
