Question about Ovens
Setting the clock on my Roden Europa oven
I recently installed a 2nd hand oven but can't seem to get any sense out of the clock controls - flashing zero's is all I can achieve. I believe this model is French and rebadged by Roden.
I have instuctions if you would like a copy Regards ian@bscprojects.com.au
Posted on Apr 25, 2009
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
Oct 05, 2014 | Thermador Ovens
I've read the "getting started" instructions regarding the auto matic switch on and it doesn't seem to make sense. I can get it to turn off automatically but not on. Sorry for being dim.
Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time.
Hope this helps
Feb 21, 2013 | Neff Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do I turn my omega oven europa 60-1 on? I turn the knobs, the electric clock is flashing but nothing comes on?
Can anyone tell me how to turn off my omega europa 60-1 oven. I have put both temp and fan to off but oven fan still going Help please as cannot find isolating switch thanks
Oct 08, 2011 | General Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Ovens Logo
263 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
