Question about Palm Treo 600 Handheld
Override
Hi, i am wondering which information overrides which. For example, i have both in the palm and in outlook a doctor appointment. Then, I change the appointment time in the outlook. when i hotsync with outlook, can i specificy that outlook should override palm? what about vice versa? same issue with updating contact lists. i have treo 600 tmobile. Thanks.
    Novelist:
  • 171 Answers
Re: override
What you're talking about is what is called a "collision" when it comes to syncing devices. You use the options in the hotsync manager to decide how to handle collisions.
Open Palm Desktop.
Go to Hotsync->Custom
Pick the outlook calendar conduit
Select if you want to synchronize intelligently, have outlook overwrite the handheld, or have the handheld overwrite outlook.
Typically if the treo detects both records on outlook and on the treo, and you've set it to synchronize intelligently, it will make dupliate records and post a message at the end of the hotsync operation.
Posted on Jan 25, 2008
0 characters
3 Points
How can i do an upload from the data saved in my software without including the text messages. I think there might be something in the text messages caausing a virus on my phone. The softeare has several...
Backup the entire phone, it will create a directory on the computer, then you can delete the message file and restore your phone. You can also change the settings to not backup your messages if you use the Palm desktop, this is not an option using the Outlook conduit however as your messages sync to Outlook.
Oct 01, 2009 | Palm Treo 755p Smartphone
Palm Treo synchronize calendar daylight savings time
You need to go to your phone carrier support page, or to Palm.com and download the daylight savings time update.  You SHOULD keep network time checked unless you don't want to pull the proper time from your carrier, such as when you are out of town.
Mar 24, 2009 | Palm Treo 700w Smartphone
T5 Outlook Calendar Synchronization failed - Any one have a fix?
I went to the MY COMPUTER folder, clicked open PROGRAM FILES, open PALMONE folder, open the username folder and deleted the back-up files. However, before I did this I deleted all of the problems dates in the PC calendar and set the hotsync to PC overrides handheld. While this works, unfortunately I have found that I need to do it every once in a while which is very disappointing. It seems that Windows does not operate seamlessly with the Palm T5. I find that the hotsync crashes 50% of the time forcing me to reset my Palm T5. No information is lost, but it is really a pain in the *** to have to do so often. Versamail hotsync sometimes freezes on the handheld, but that is another issue which I have managed to fix much in the same way as describe above.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Can't synch Outlook Calendar Appointments
Try uninstalling with Windows Uninstall Clean-up tool. XP seems to do a poor job of installing conduits sometimes. I think this might be an issue with the one conduit no being registered correctly in the Windows Registry. You can get this tool here: http://support.microsoft.com/default.aspx?kbid=290301 Uninstall Palm Desktop. Then shut down the PC. Then start it up again and re-install Palm Desktop. I hope this helps.
Sep 11, 2005 | Palm Zire 31 Handheld
Time difference
Try to reset your time in your phone and try synching
Sep 11, 2005 | Palm M100
2 users, 2 Zire31s, 1 Outlook
hi, u will not able to sync ur data into ur husbands profile for eg: as u know u would be having ur username on ur zire and ur husband will be having his so there is no way u would be able to merge both the data , what u can do is when ur syncin ur palm to outlook u can sync it with ur profile and when ur husband's sync 's his zire he can create a new profile and sync it , and if u plan of using the same username then , u would get an error sayin duplicate username is found .... Regards
Outlook Meeting Requests Changing
similar problem with my Palm Vx syncing with Outlook 2003 My recurring meetings lose attendees and other attributes like labels when I make a change to a specific date in the recurring series. If I leave the original recurring event untouched the problem does not occur
Sep 11, 2005 | Palm Tungsten T3 Handheld
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
Appt. made on Palm syncs as an "Invited Attendee" event.
on the free time issue, here's a workaround that I tried and seems to work: go to the PalmOne Knowledge Library and search for Solution ID 4971. Appointments made on the Palm show up as busy in Outlook.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm Treo 600 Handheld Logo
162 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
