Question about Dell Latitude D600 Notebook
Battery not charging
My battery was not charging, when I would unplug my computer it would shut off almost immediately. I bought a new charging cord, that didn't help. I bought a new battery, it seemed to work for a few days, but now I am back to it shutting off immediately after unplugging it. Please help.
  • 22 more comments
  • bethaniera Aug 30, 2008
    the battery icon? then no it isn't there
    yep
    I just removed and reinserted the battery and yes the tab slid back into postion on it's own
    No, that battery indicator light is blinking red 4 times the once green.
    My computer?
    Dell Latitude D600
    Battery Model LDED600
    Actually no, that charger had over heated and the box in the middle was warped. So, I threw it away.
    battery is correct,
    charger 19.5 volts.
    Could this be my problem?
    thank you.
    Should I be worried that it fried my new battery?
    I do have a desktop as well. Thank you for your help. I guess I will be making a purchase of a new charger.
    model JP-65-0V
    I tried both of these solutions and neither worked. On the outside of the battery is an area that appears to be able to show me battery life or something. When I depress this area no lights light up. Could this possibly mean the battery is a dud?
    Now in my power meter it says I don't have a battery installed.
    there is only one place to put the battery. Flipping the computer over it goes under where your right hand would sit when typing.
    I went in the powercfg.cpl and it is in there
    no, it says "Not present" for both a first and second battery. I only have one, but it has the capabilities for 2
    It was showing an "X" over #1 with 0% beside it. Now it says "Not present"
    The contacts seem ok. There is a small battery.
    no, sorry I don't.
    I'm not sure about shops locally, I will have to ask my husband. As for the battery, he bought it on line for me. I'm not sure where it came from.
    I will be away from the house this evening, (family reunion) so I will check back in late tonight or early morning. Thank you for your help.
  • bethaniera Sep 02, 2008
    Thank you for all your assistance. I will have to purchase a new one.
  • Roberta Smith
    Roberta Smith May 11, 2010
    The replacement battery was brand new ?
    Robert
  • Roberta Smith
    is there an icon in your system tray.... lower right hand on the taskbar ?
    Robert
    Problem Solver:
  • 14 Answers
    Brigadier General:
  • 5,158 Answers
When you installed the battery... did the tab move all the way back after you installed the battery.... you have to hold the tab in the open position while you install the battery.... after it is firmly seated release the tab and it should slide back in position. if it doesn't and the battery appears to be seated properly push the tab back into place.
Robert
Posted on Aug 30, 2008
  • 14 more comments
  • Roberta Smith
    Roberta Smith Aug 30, 2008
    but it still isn't charging ?
    Robert
  • Roberta Smith
    ok ... i'll need the brand and model number again i need to do some research.
    Robert
  • Roberta Smith
    yes... and the number on the battery would be helpful as well.
    Robert
  • Roberta Smith
    I may have found a couple solutions.... first do you still have the old charger a/c adaptor ?
    If so plug that into your laptop and try it.
    Other options but lets try that first
    Robert
  • Roberta Smith
    two more things as well... examine the battery you have. the voltage should say 11.1 volts. the charger should say 11-16 volts output.
    Robert
  • Roberta Smith
    Wrong charger... i suggest you remove it till you get the right one
  • Roberta Smith
    there is a chance of that .... i presume you have a desktop computer as well .... but i'd take the adaptor off the laptop
    Robert
  • Roberta Smith
    ok i'm annoyed with myself. one charger i looked up was 11-16... another was up to 19 volts..... let me do some more looking .... i'll post some other solutions after i confirm what charger that should be.... it might be handy to give me the model number of the charger you are using ...
    Robert
  • Roberta Smith
    i'm not sure why one site has different information about the charger and another site has other information. be that as it may the correct voltage appears to be 19.5 volts.
    So here are two options that appear to have some success.
    first
    1. Remove battery from unit.
    2. Unplug AC adaptor
    3. Hold down power button for 5-10 seconds.
    4. Wait 1 - 1 1/2 hours before reinstalling battery.
    second
    I have found by letting the computer go through the process of going into stand-by and waiting for it to then go into hibernation, it resets the battery. From this point, recharge the computer battery and the blinking will stop. This is about a two-day turnaround. It has worked for me 3 times now because I keep allowing the battery to discharge too much and the blinking restarts.
    I have a dell inspiron 3800 ... good laptop ... lousy battery.
    Try the first option and let me know how it goes. i'm sure you are frustrated with it as i would be.
    Robert
    Robert
  • Roberta Smith
    It is basically a meter to tell you how much charge the battery has.... which side of the laptop are you plugging the battery in. if i remember right ... you can use either front bay for a battery. i'll go find the manual shortly to confirm that. As i said i owned a inspiron so that was an option.
    perhaps you own one or you have a friend that has a multimeter. the next thing i would do is check that the voltage on the charger is what it should be.
    Robert
  • Roberta Smith
    which power meter ?
    Robert
  • Roberta Smith
    give me about 5 minutes to get the manuals for that. when you go into that... does it show that the battery is charging ?
    Robert
  • Roberta Smith
    Ok ... from looking at the manual there are other things to try but first.... turn off the laptop and turn it over... remove the battery and inspect the contacts where the battery plugs in... do the appear damaged in any way ?
    Second ... toward the front there is a little door ... just like the battery door on the remote for you tv.... open that to confirm there is in fact a small battery in there. it should be present as you haven't mentioned the laptops failure to keep date/time.
    Robert
  • Roberta Smith
    I suspect i am missing the merely obvious... in the meantime while i think this over. do you have a meter to test the output voltage of the charger ?
    Robert
  • Roberta Smith
    Testing the output voltage of the adapter would eliminate one suspect cause. i'm not sure if you live near any shops that would test that for you. the second suspect at the moment would be the battery. did you buy it at a local computer shop/store ? If so i would suggest returning it and getting a replacement as it may very well be defective.... i'll do some more research today after i've done my shopping etc.
    Robert
  • Roberta Smith
    Roberta Smith Sep 01, 2008
    The best thing i can find as a solution appears to be that the battery is in fact defective.
    Robert
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
I think I have a PMU problem: just bought a new battery for my 6 year-old Compaq Presario and it worked fine until a week or so ago. When plugged in the battery shows a full charge (which previously would...
It sounds to me that the battery is not connecting to your computer. Is it possible that the terminals have been damaged? Or some other issue that is disconnecting the battery from the computer?
Oct 02, 2013 | Compaq Computers & Internet
Toshiba laptop will not turn on without adapter
i think your battery place has something wrong so the electric can go or there is some space between battery and laptop
Dec 13, 2012 | Toshiba Computers & Internet
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Nov 19, 2010 | Computers & Internet
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
Apr 23, 2008 | Compaq Presario R3000 Notebook
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Dell Latitude D600 Notebook Logo
819 people viewed this question
Alun Cox
