Question about Sanyo Microwave Ovens
Microwave model No EM-X471S light globe has blown
  • Sanyo Master
  • 9,086 Answers
You can get Sanyo UK support and spares here.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 01, 2008
I wish to replace a lightbulb
MOSTLY A SAMM DOOR ON THE SIDE...U NEES A SCREW DRIVER..OPEN IT UP AND REPLACE THE GLOBE..AND REFIT THE DOOR
Oct 18, 2013 | Sanyo EM-S5002W Microwave Oven
How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Jul 04, 2010 | Microwave Ovens
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
Jun 21, 2010 | LG Microwave Ovens
Light comes on and turntable moves but not cooking Model EM-G4775S 900 watts
Fuse blown? Needs to make high voltage for the magnetron. A blown fuse usually means trouble in the high voltage system (a shorted HV diode or maybe a bad stirrer [metal fan-like device] bearing which is located just above the interior case under the waveguide assembly). If suspect, replace the stirrer as a unit. If fuse looks ok, maybe bad door interlock switch or not being operated by door closure.
Aug 03, 2009 | Sanyo Microwave Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Microwave Ovens Logo
54 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
