Question about Insignia NS-DV2G MP3 Player
How do i upgrade the firmware if icant turn it on.
  • Jleec1992
    Jleec1992 Aug 30, 2008
    Oh thanx man ive been searching for months on how to fix this.
  • Insignia Master
  • 1,800 Answers
I told u its
www.s1mp3.org
follow the instrucyions ^^
plz rate it
Posted on Aug 30, 2008
WHY CAN'T SAMSUNG FIND MY TV MODEL TO UPGRADE?
Because there is no upgrade for your model TV. It may be too old or too new. It may be a model made for a company like Walmart that asked for no upgradability to save money.
Feb 23, 2015 | Samsung LA26A450 26 in. LCD TV
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Camera will not turn on. it shut down when turn power on. is it iossible it's the battery
I know exactly the model, but may be a bug that needs reset, see the Internet, in a similar model is to get the Fimrware, download to the SD card and do what follows.
1. Turn on the Camera
Press and hold the Up button and the Shutter button (S2) simultaneously and then press the Power button to
turn it off.
Turn on the camera and check whether the camera is reset or not.
This is a lastset upgrade and full firmware for S860 camera.
(UP/FULL ver. 803141)
- Improvement -
1. How to UPGRADE firmware(Upgrade version)
-.Insert the SD card that has the firmware attached file.(file name : "S483.ELF")
-.Turn on the camera and press the Up button twice to select the Voice recording mode.
-.Press the 5 function button as following order. (Left button -> Right button -> Up button -> Fn button)
-.After pressing the buttons, Firmware upgrading is shown on the LCD and then the firmware will be upgraded.
-.After upgrading the firmware, the camera will be turned off automatically.
Feb 10, 2011 | Samsung Digimax S630 Digital Camera
My psp is a 6.35, icant download anything at all? whats up with that?
Unfortunately if you have upgraded your PSP past 5.50 firmware you cannot downgrade it or install any version of custom firmware. Until a custom version is written there is no way to downgrade it.
Sorry to be the bearer of bad news
Hope this helps and thank you for using FixYa
Dec 18, 2010 | Sony PlayStation Portable (PSP) Slim...
Won't boot up and not recognised when connected to PC
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
My colour printouts from new Samsung CLP-310 do not match original WORD 2000 docs colours (or compared to HP deskjet. Is there a MS patch for this?
There is an update for your printer. This is a firmware update. A firmware update, rewrites code located on the printer's main system board. The latest update is dated 10/17/08.
Flashing firmware does not have a go back element or undo, so it is really important that we verify your model and what seiries of printer you have. I suspect you have a CLP-300 Series printer and that the 310 of the 300 just describes some features added or left off and even who you purchased it from, in many cases.
Please look at these two photos and then post the data off the name plate for your model number in particular.
You will notice there are two lines to include in your reply.
1.) The Model: (first line)
2.) M/C entry (second to last entry in this photo of the label.
Once you verify this and I post the firmware update link for you, you will need to follow the instructions I include below.
Regards,
Worldvet
[from Samsung.com PDF file on this firmware upgrade]
Samsung has released a new Software upgrade file for print quality, automatic error recovery, and toner save mode on color laser printers.
Procedure to Set-up Download Mode on Your Printer - CLP-300 series
Turn power off.
While holding down the ‘STOP’ button on the Printer, turn the Printer back on.
Keep holding down the ‘STOP’ button until all the LEDs turn orange.
Then release the ‘STOP’ button, and press it again, one more time.
1. How to Upgrade
Please make sure to check the printer model number before performing the firmware upgrade.
2. Release Notes
Improved on light printing quality at low temperature environment
Automatic error recovery at abnormal operation
Toner save mode by optimized toner supplying
3. Caution
After firmware upgrade is completed, green LED lights will light up.
Do not turn off the printer before green LED lights turns on. A power interruption will corrupt the process.
If the printer is connected by a USB cable, disconnect all other USB devices, except your keyboard & mouse, from the computer.
If possible, be certain the Printer is connected to a BackUPS
Firmware Update Confirmation Instruction
Model CLP-300 series
When firmware upgrade is started, status LED light will start blinking.
As the printer reinitializes, status LED light will automatically turn off and then on.
Firmware upgrade is complete when status LED stays on green.
After firmware upgrade is completed, the LCD will display the message ‘Ready Copy’ and the LEDs will stay on green.
4. If there is an Error after firmware upgrade
If LED is on red or blinking after firmware upgrade, set-up download mode again and re-try the firmware upgrade.
Oct 20, 2008 | Office Equipment & Supplies
Creative Muvo v100
try to reformat your mp3 player. maybe it contains malicious programs and viruses when you connect it to the computer.
Jan 17, 2008 | Creative Labs Muvo V100 MP3 Player
How do I upgrade the firmware on my DI-804V?
To upgrade the firmware on a DI-804V follow the steps below: Step 1: Download firmware from our support site. Save and unzip it to your desktop. Download Firmware here. Step 2: Access the configuration page by entering 192.168.0.1 in your web browser. Step 3: Click on the System Tools tab and then click Upgrade Firmware on the left side. Step 4: Click the Browse button and locate the firmware file that you have downloaded and unzipped. Highlight this file, click Open, and then click Start. Note: When upgrading the firmware, do not try to access the Internet and do not turn the power off. Doing so may cause the firmware upgrade process to abort, which will damage router.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
I do not feel comfortable performing the installation the Optional Enhancement Upgrade for DiMAGE 7, can I have the camera upgraded professionally?
If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, they can send the camera in to the NJ repair facility with a note stating "Please Upgrade Firmware". Their camera will be upgraded, and they will be charged $49.95 (plus tax and shipping). They will receive back their upgraded camera, and a DiMAGE Viewer Ver 1.2 Upgrade CD-Rom*. (They will not receive the firmware upgrade on CD-Rom or the new DiMAGE Viewer) There is a 2-3 week turn around time once payment has been authorized. * images captured with an upgraded camera cannot be opened using previous versions of the DiMAGE Image Viewer Utility 1.11 or earlier. A DiMAGE Viewer Ver 1.2 upgrade CD-rom has been bundled with the DiMAGE 7 Optional Enhancement UPGRADE Firmware. The previous version of DiMAGE Image Viewer Utility must be installed before the DiMAGE Viewer (Ver 1.2) update can be loaded. If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, but they want the DiMAGE 7 Optional Enhancement UPGRADE and the New DiMAGE Viewer 2.0, they should purchase the kit through our on-line store, then send the camera in to the NJ repair facility with the Firmware UPGRADE CD-Rom that they purchased. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received. If customers attempt to install the firmware upgrade on their camera and experience a problem, or the upgrade does not complete, they should send the camera in to our NJ repair facility with the Firmware UPGRADE CD-Rom and a description of the problem. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Insignia NS-DV2G MP3 Player Logo
37 people viewed this question
Top Insignia Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
tk007
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
