Question about GE 29893GE1 Corded Phone
When I plugged the phone in, a "flash error, see manual" came up. I don't know where the manual is, so don't know how to fix this problem.
I dont have a solution, I need help.
Posted on Sep 13, 2008
Culligan gold series alarm 1 error
Hope you got this fixed Oscar, Since you have a manual and everything you've tried hasn't worked consider it either broken or something has failed. Could be a filter element you can change or a sensor that has failed. I haven't found a manual to look at so don't know if this system has any parts you can check or change. Also could be a UV bulb if it has one or the timer that calculates the bulbs life. Sorry not much help.
Sep 01, 2012 | Culligan Sediment Water Filter Heavy Duty
Tip
THE ONLY WAY I KNOW HOW...PART2. fUJI FINEPIX/ SAMSUNG DIGIMAX
The headache that is "ERROR 99".
The common, works for everything, general fault code.
Doesn't tell you alot in the manual, except consult your nearest dealer...
Fantastic...
So, what does it refer to??
Well, Your camera works to a program and parameters and if one of these goes down and the cause cannot be isolated by the software then a fall back, general, fault code will apply. error 99..
If its a lens issue with communication then try a different lens to isolate the fault. Clean the contacts with lint free cloth. Don't use solvents as the contacts are gold plated and solvents will remove the plating and then you will be in trouble..
Error 99 could mean anything so try to isolate the fault by adjusting settings etc or replacing the batteries (main battery and c-mos battery).
Finding out what,where, why and when is how I start with Error 99 so as much info as possible.
Power loss/drain is a usual common fault. Mainly to do with the flash.
It won't pop up, won't fire etc..
The "Busy" sign is the give away. You press the shutter button and the busy sign flashes (sometimes for ages and then still nothing) Its trying to charge the flash but there is a problem with the circuit or components. Whilst this is happening power is being diverted from other circuits and causing more issues..
There could be thousands of reasons why.
Replacing the flash capacitor has always worked for me. It's a battery with an extremely fast discharge rate and charge rate. It wears out...Quicker than you think.
Don't forget everything made today is from the cheapest manufacturer. made with cheap materials for the disposable, throw away world of today.
on Apr 10, 2009 | Canon Eos Cameras
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
I am holding nokia 5230. I am faceing bluetooth connecting problem " When i turn on the bluetooth it show a message "UNABLE TO PERFORM BLUETOOTH OPERATION". Kindly advise me who to resolve...
This problem can be fix in 2 steps.By updating the firmware or a bluetooth IC replacement.
If you want DIY method for fixing the software,
* download this application to your computer and install it. NOKIA SOFTWARE UPDATER ,if installation is done, run the software and plug your phone to the computer by using usb cable,be sure internet connection is stable and back up all data first before proceeding,also battery must be full charge to avoid errors. Upon plugging the phone to computer,some driver installation takes place and let it finish,then follow the instruction on screen when updating,then wait until the update is done.
Now if the update is successful and then the bluetooth still don't work, just bring the phone to any service center near you for a complete diagnose and troubleshooting.They know what will do further.
For any question,please reply here to know the status of your mobile,
Thank you for visiting FixYa...
Jul 06, 2011 | Nokia 5230 Cell Phone
I have a verizon 9530 Blackberry storm hat has been flashed to cricket. I have never had an issue until now. My text message are unable to be sent out and when I try to access the folder for SMS inbox I...
This is a Java (OS) error and is usually caused by a application or possibly a file that is corrupted. Lets start with the easy stuff and see if we can get this corrected.
Try this first in this EXACT order!
Remove the battery from the phone and wait 20 seconds, then, with the battery still out, plug it into your wall charger, then place the battery back in and turn the phone back on.
You do that by downloading the Blackberry Desktop software if you don't already have it (see link below.) Then plug in your Blackberry, open up the software and go to "Device" and then down to "update my device." and see if there is a update available.
http://us.blackberry.com/apps-software/desktop/
In case, if that would not help, you need to get the new phone. You could also call Verizon and see, if there is any recent update for your phone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | Cell Phones
While downloading any application i m receiving error stating " certificate not found on phone or sim" kindly help. nokia 5130 xp.
JUST FLASH YOUR PHONE AND EVERYTHING WILL BE FINE. I RECENTLY GOT THE SAME ERROR AND I DO FLASH. IF YOU DONT KNOW FLASHING THEN VISIT TO YOUR NEAREST MOBILE SHOP AND TELL THEM TO FLASH IT.
Apr 18, 2011 | Nokia 5130 Cellular Phone
I have a rinnai energysaver 556f heater and the "On" buttons keeps flashing and it feels like it's blowing cold air. The "LO" button keeps flashing as well. What does this mean?
It is telling you that there is an error code stored in the EPROM. Press and hold the Economy button and the Up and Down arrows for 5 seconds. Get ready to tell an assistant the codes as they pop up. You may have to do this a few times to get them all. Repost the error codes here on Fixya if you don''t have an owners manual to interpret the codes.
Feb 25, 2011 | Heating & Cooling
GE 29893GE1 Corded Phone Logo
94 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
