Question about Kenmore 24032\24036 Top Load Washer
Kenmore Clothes Washer
VERY FRUSTRATING !!!
Keeps flashing "FL"
Tried to wash small bath rug....flashed "OB" so took rug out
Tried to run the rest of the small load but now washer keeps
displaying "FL" the only way to stop that display is to unplug\
stop/cancel - turn off does not work !!
What is FL and how do I remedy.
Here we go into the holiday weekend !!!!!!
OUCH ! HELP !!!
Penny Hon
pbhon@aol.com
  • 1 more comment
  • pennyhon Aug 30, 2008
    What does F1 mean and how do I resolve and get my washer going again ???
    Need to know, not just stand by....
    Okay, the overfill switch is not kicking in.
    This has been going on for about 6 hours...
    3 hours of which the machine has been un-plugged.....and when I re-plug, it just keeps beeping!!
    Maddening !!
    Is there NO solution ???
    Not very -- all you said was to contact a repairman.....I could have done that without
    going to all this trouble with you, and spending
    the $10.00 for nothing !!
  • 725 Answers
FL is Flood condition
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
OB is Off Balance
If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Posted on Aug 30, 2008
  • 435 Answers
Hi pennyhon, I have had the same problem, there is too much water in the basin. I actually have a repair man coming over in the morning to replace the pump motor. There is a way to make the pump drain without cycling the washer.
To get the machine to drain after receiving the FL code, push SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL alternately... you should have a "dt" code now, then push the Jeans/color mode and this will activate the spin and drain test. It will drain the water out of the basin and shut off after 40 seconds.
If this does not work, you may have a problem with the pump motor.
I hope this helps..
Thanks
    Master:
  • 848 Answers
You are getting this error because there is too much water in the basin.......
To remove FL code try this push set delay time end of cycle signal , set delay time end of cycle signal alternately... you should have a dt code now, then push the Jeans/color mode and this will activate the spin and drain test. It will drain the water out of the basin and shut off after 40 seconds.
    President:
  • 1,263 Answers
Fl means fault. you could have a glitch in the circuitry behind the main panel. due to vibration connections in the circuit boards can come loose or the board cracks. it would seem that even though you unplugged it and plugged it back in the restart rset did not solve your problem. your only option is to have it serviced by a appliance technician. i know that's not an easy fix but better sooner to do this than to have your whole brainbox malfunction which would cost more money. please rate this solution and thanks and good luck.
  • 13,433 Answers
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
    Sergeant:
  • 241 Answers
HI There I will help you
I am looking for the answer please be stand by.
  • 2 more comments
  • Jayson Brollini
    Jayson Brollini Aug 30, 2008
    First of all, unplug your washer. You will need to remove the console
    in order to get to the lid switch. I believe your washer has release
    tabs under the console at each front corner. Simply slide a putty knife
    straight in from the front at each corner and push in while lifting up.
    You should feel the release tabs push in and the console will pop up.
    Or, you may have a console that has removable end caps. They can be
    removed by gently prying up on the top of them from the rear on each
    side. You may have to use a small screwdriver for this. The caps should
    pop right off. Once removed, you will need to loosen a screw under each
    cap. Once you have the console loosned, carefully lift it up and lay it
    back over the rear panel of the washer in its resting position. Be
    careful not to damage the small plastic hinges that hold it in place.
    Now you will need to perform the following steps:
    1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
    2.
    There will be two brass colored clips. You will need to remove these to
    remove the machine casing. Place a flat blade screwdriver straight down
    into the opening on top of the washer and into the groove of the clip.
    Push the screwdriver away from you while holding into the groove and
    the clip will release.
    3. Open the lid of the washer and place
    your hand under the front rim of the opening (DO NOT grab the wash
    tub). Now pull the case from the frame by lifting from the back first.
    You
    do not have to remove it all the way from the frame. Just enough to
    gain access to the switch. All there is to the switch is a couple of
    screws holding it in and a ground wire. It's a pretty easy repair job.
    Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
    1.
    While looking down through the lid opening, place the front lip of the
    machine case UNDER the washer frame and start leaning it back onto the
    frame. There are four small cleats that must fit into four slots on the
    case or the washer will vibrate. Make sure the frame is seated
    properly, lean forward from the front of the washer, grasp both sides
    of the rear panel and pull towards the case. The rear panel should be
    seated and flush with the casing before inserting the retaining clips.
    2.
    Insert the brass-colored clips into the slot on the washer rear panel
    first, then push straight down into the opening on the top of the
    washer with some force. If you have the case seated correctly, the
    clips will snap back in.
    3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
    I hope you find this helpful. If you have any questions please let me know by posting comments.
  • Jayson Brollini
    PLEASE DO NOT FOLLOW THAT SORRY ABOUT THAT
  • Jayson Brollini
    Make sure there is nothing caught in the door latch small objected
    the door is shutting fine did you also check to see if the agitator is has any thing wrap around it like a sock. also unscrew the top piece of the agitator and clean that off . You should be able to lift a part of it up so you can clear all deb-re out
    ( plz let me know for or if this darn thing works)
  • Jayson Brollini
    SORRY WE COULD NOT HELP
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL FLASHING
Look for the tech sheet which will be behind the lower front panel. It will be taped to the right side of the lower cabinet or taped to the back side of the panel that you just took off. This will have what FL means. Send the model number back and we will figure this out if the tech sheet is missing
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washer keeps beeping Fl
Your pump is clogged , It is a very bad Idea to put rugs in that machine either to fibers or the backing on the rug gets stuck. I hope you know someone handy. take out as much water as you can from the top with a cup or something. You are going to have to go under the bottom of the machine remove the 3 screws on the bottom plate. the pump is on the right you have to disconnect the black and the yellow hose very slowly there is a lot of water that you can't see from the top . then take down the pump and clean it out . Good luck remember no rugs.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite flashing codes.
ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
KENMORE ELITE CALYPSO
Call Kenmore if you bought it new they may have a record of your serial number and be able to tell you what the error message means and if you need a service call to fix or you can do it yourself. my serial number is on the back of the washer on a sticker or a typed silver tag that is attached to the washer.
Oct 03, 2017 | Washing Machines
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Calypso Washer
take the pannel off the bottom and unscrew the pump cleanout
Feb 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore washer starting
"FL" is an over fill indication. Unplug the machine first (if you haven't tried that already) in an attempt to clear. If the problem persists, check all connections going to your control board, which is located under the control panel. Take them off one at a time and look for any contacts that may be corroded or dirty. This could be an indication that you have a bad control board, or a pressure switch that is starting to malfunction. Let me know if this helps.
Jun 22, 2007 | Kenmore 24082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
175 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
