Question about Panasonic SC-HT700 System
Getting F61 in Display of Panasonic SC-HT700
I just got a new flat panel HDTV and connected my home theater system to it but when I try to power it up I get a display of F61 and it powers off.
I am looking for the cause and the fix for this problem.
  • cdavis8107 Nov 16, 2008
    How can fix this problem. I get the F61 code when I hit power button???
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Posted on Nov 04, 2009
My panasonic stereo system SC-VK550. my cd is no open show in F61 Other not open my plyar what is this F61 How to my problem sholf how.
F61 usually means the amp has detected a short or has a microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 15, 2011 | Panasonic SC-HT700 System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
Hi i was hooking up my panasonic home theater with the power on i heard a sound and the power came try power it up went on display f61 and then shut off what seem to be the problem model...
Never hook up theater units with the power on, you need to have the fuse replaced in your unit. You need a trained tech. for this electrical problem.
Oct 19, 2010 | Panasonic SC-HT740 System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
NOISEY FAN
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Jan 10, 2009 | Panasonic Home Theater System System
Display showing "F61" some electricity failure
you have a problem with speaker cords:-
1-make marks with tape or any marker pen in all speaker cords(left-right-sub- front-rear).
2-after marking remove all speaker cords.
3-insert them one by one until f61 appear.
4-the cord that connected and make the trouble is bad please change it with new one.
Mar 07, 2008 | Panasonic SC-HT75 System
Panasonic SC-HT700 System Logo
680 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
