Sewing Machines Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you unlock the safety device on a babylock espire sewing machine without going back to a dealer?
R.A. Ellis
Level 3:
  • Baby Lock Master 12,731 Answers
  • Posted on Nov 19, 2017
R.A. Ellis
Baby Lock Master
Level 3:
Answers
12731
Questions
Helped
2618789
Points
59176
The safety lock is usually triggered because there is a possible safety issue with your machine. As such, it should be reset by a technician.
NOEL
Level 3:
Top Expert:
  • Baby Lock Master 8,606 Answers
NOEL
Baby Lock Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322047
Points
68630
Hi Katester.
not sure if you have the manual but if you go to this link it has the manual and you can read up on it.
http://babylock.com/ftp/whitepapers/Espire_BLSR_InstructionManual.pdf
or go to this link but i could not find much on there but have look.
How do you unlock the safety device on babylock espire sewing machine...
5 Related Answers
Anonymous
  • Posted on Oct 14, 2008
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
Anonymous
  • Posted on May 17, 2009
SOURCE: tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
Anonymous
  • 1116 Answers
  • Posted on Mar 21, 2010
SOURCE: babylock manual sewing machine
You can download from this site - http://www.babylock.com/sergers/imagine/
RichSew
Douglas Plant
  • 222 Answers
  • Posted on Jun 03, 2010
SOURCE: Babylock espire bobbin sensor not working
This is normally caused by lint in the bobbin area, the lint blocks the sensor causing it to be blind. Try cleaning the area and see if that helps.
bargainbox
Hassy
  • 1388 Answers
  • Posted on Oct 17, 2011
SOURCE: bottom thread is looping.
Check this solution:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
3answers
Baby Lock Espire with apparent electronic failure.
Hi Jean.
click on this link and you might find out why its doing this.
https://www.google.com/search?client=avast-a-1&q=Babylock+Espire+with+apparent+electronic+failure.&oq=Babylock+Espire+with+apparent+electronic+failure.&aqs=avast..69i57.4599j0j9&ie=UTF-8
2answers
How do I oil my babylock serger
That depends on the model. The Babylock Triumph (BLETS8) does not get oiled by the user. However, the Babylock Diana (BL480A) needs to be oiled at 4 different points. See the picture on page 63 (page 64 of the PDF) of the manual. Babylock has the manual here: https://babylock.com/resources/5148/download . Current Babylock sewing machine and serger model manuals are available here: https://babylock.com/support/machine-support .
Please add a comment with your serger model. I'll try to find the oiling diagram, if the machine needs regular lubrication. Do not oil any sewing/serger machine unless the manual recommends that as part of the maintenance of the machine. Some Babylock sewing machine dealers will provide you with the manual, if it is available for a small fee. The Babylock serger that I have access to didn't come with a manual. However, we were able to get one from the dealer.
I hope this helps.
How to change the thread spool pin on babylock model esp
Depends. Some spool pins simply push in and snap in place, but as many machine brands existing, there are probably double the different spool pins available...
http://www.sewingpartsonline.com/babylock-esp-sewing-machine-parts.aspx If you order from one of the online vendors, they will probably be able to advise how to install it.
Spool Pin for Brother Baby Lock X59053051 Old X59053022 X59053052
SPOOL PIN Babylock ESL ESP Espire Brother CS8072 PC2800 PC3000 PC6500...
The computer pressure foot button on the espire does not work
If it's an electronic presser foot lift you will have to take it to a babylock dealer for repair. If you mean the automatic stop/start button, make sure your foot control isn't plugged into machine first. If it still doesn't work, you will have to take it to a dealer for repair.
The safety device has been activated
Turn the machine off. Check for a broken or bent needle or a bird's nest in the bobbin area. Sometimes when I try to put an extra heavy piece through the machine I' ll get that message. The most common reason for the error is a broken or bent needle.
1helpful
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
I lost the power cord to my baby lock espire when I moved. How do I get another one?
Contact a local dealer and they can order you one. If you don't have one in your yellow pages, I believe you can find one at Babylock.com
3helpful
How to get the safety device actived error to go away and sew again???
The reason you are getting this messege is because something is in a bind, could be a shaft or even on of the step motors. You will need to get in into your local Babylock Dealer and they will be able to find the bind fairly easily.
I personally have 25 years working on Babylocks and am familiar with this problem
Top Baby Lock Sewing Machines Experts
vince
NOEL
NOEL
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
