Question about Whirlpool Refrigerators
Whirlpool Refrigerator ED22PQXDW01 temperature is all over the place in the refrigerator from 36-38 up to 52-54 degrees. it seems that the vent holes from the freezer gets ice crystals forming on it almost to a point of freezing over. all this happens when something is put in the re-fridge that isn't already cold like a plate of left overs. or anything. have had s service men look at it to no avail. fan is working in the freezer and there is proper amount of freon gas.
  • 1 more comment
  • gtrapane Aug 30, 2008
    The defrost cycle is working, the coils in the freezer side are not freezing up just..... the small vent holes between the freezer and the re-fridge get ice crystals in them. service man had the back of the freezer removed everything seems fine in there..
    Thanks But that was a good guess, i know what you mean, A kenmore i had a while back kept getting warmer and warmer in the re-fridge side, and that was the defroster, the unit had a wire burnt off it and was replaced
    Ignorance and ego Huh
    I dont protest to know refridgeration! ....There have been 2 factory repair companies here for this refridgerator and neither have been able to fix the problem. Their solution is to start replaceing parts one at a time and see if it fixes it. I Thought you would know.... May be if you could loose a bit of your arrogance you would be more helpful to other people too.
    Thank you for nothing.
    Thanks for your persistence. I Will take action on the defrost problem as suggested.
    again thanks
  • 725 Answers
If it freezing it is not a freon gas problem...
Sounds like a defrost problem..
first to get it to work again.. take all the food out .. unplug it .. open the doors and wait 24 to 36 hours..clean up all the water .. then plug it back in .. it will work for 2 to 3 weeks until a repair man can come and repair it for you . or let me know and I can step you thru the repair... let me know...
Posted on Aug 30, 2008
  • Franklin Ouchida
    Franklin Ouchida Aug 30, 2008
    Your ignorance and ego really shows... WHY ? do you ask for help but think you know what the problem is ..Where do you think the frost in the vent comes from...I know but there is No reason to try to help you...Thanks for trying ....Hope you get a Real tech .and he charges you some real money...
  • Franklin Ouchida
    Factory Tech are parts changers .. that is what they do..
    that is how they are trained...
    I do know you have a defrost problem.. your air flow is blocked by frost...frost is build up by warm air leaking into you vents or cabinet...this is a defrost problem .. but you would rather leave the refrigerator plugged in and call your parts monkeys.. hope you like sour milk...
Dorm refrigerator freezes everything
Lower the freezer letter by one letter, let set 24 hours for temp to stabilize, keep lowering until right temp/environment is achieved.
The temperature of refrigerators should not be allowed to exceed 41 degrees F as this will contribute to the growth of bacteria in the food, and cause different health problems, including food poisoning if consumed.
A temperature below 34 degrees F in the refrigerator may cause the food to freeze, and you will have to defrost it before using it. If this happens to vegetables and fruits they will go limp and will be rendered inedible.
At any time when you change the temperature, give it a minimum of 24 hours to take complete effect.
The external temperatures also influence the internal refrigerator temperature. This means, you will have to set your refrigerator lower in summer, and higher in winter, especially if you live in extreme climatic conditions. On the other hand, if the climate in your zone is moderate, your refrigerator temperature will be less affected by external temperatures.
In order to check and ensure the internal temperature of the refrigerator, you may place a thermometer kept in a glass of water in the fridge. The exact temperature will be available to you anywhere within 5-8 hours.
For your refrigerator to cool effectively, it is essential that your air vents are functioning well. Do not place any items before it, and clean it on a regular basis for maximum effect.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Kenmore Refrigerators
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    Freezer is icing up we have already vacuumed the vents in teh front and the back of the refridge and it is still icing up
    Hello, This is a common problem, the first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35-42 degrees.Here are some things to try:
    • If your refrigerator temperature is closer to 25 degree try turning the temperature up slightly.
    • If you find the temperature varies a lot from the top shelf to the bottom(where it is coldest) try putting produce or other sensitive product on a higher shelf
    • If the temperature is too low and you cant make it warmer by adjusting the thermostats, you probably have a defective thermostat. If so you need to replace it because they cannot be repaired. Other possible problems are a leak in the seal(refrigerant) system, cold air migration(in side by side models) or a defective air damper.
    Thanks
    Jun 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Water dripping inside top of refrigerator.
    if freezer is on top what is happening is your drain hole behind freezer panel is clogged
    Nov 11, 2009 | Refrigerators
    New whirlpool refrig. freezer ok at 0 but refrig
    The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
    Sep 09, 2009 | Whirlpool Freezers
    I have a rm2611 refrigerator which has lights, no fan
    There's a capacitor by or on the compressor that probalbly needs replacing. This is the cheapest route .
    Jul 05, 2009 | Dometic RM2620 Refrigerator
    MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
    In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
    Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
    The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
    Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
    Oct 08, 2008 | Whirlpool Refrigerators
    Refrigerator freezes things the freezer works fine:
    Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
    Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
    Brand new refrigerator...freezer works great, fridge does not
    Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
    sample of air vent location :
    Apr 06, 2008 | Refrigerators
    Refrigerators Logo
    100 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
