Question about Kenmore 95022 / 95024 / 95029 Electric Kitchen Range
Kenmore Range/Oven Smooth top Model 95022107 RM3120383
Hi. I have a stove that if you turn the light on or open the door the electronics on the top start flashing and making an odd sound. I took the back off and the light 'housing' looks 'lightly browned'. where can a person get a replacement part for this? Also, I tried to take the lens off inside the oven cavity and it will not come off. I thought you just turned them and they removed. Not sure what I am doing wrong. Thanks.
  • 639 Answers
Friend,
ngfam1 at your service!
Below I will give you a 800 # that if the part is in stock they usually send parts in one business day!
The lens should tun and come off. How old is the stove and the model # ?
Usually if the lights flash this is a code that the manufacture recommends service to be used!
Bulb sockets will mostly all be a little burned color because it's in an oven!
lets see what you send me??
If you end up needing service, here is a good company nation wide that can make appointments 24/7!
A&E Factory service
1-800-905-9505
We have been in the appliance business for 65 years!
ngfam1
Bless you
Please give me a good rating before you sign off !
Posted on Aug 30, 2008
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
While oven on range top front is very hot
I do not know the unit but check if the oven vent is near the front. It is also possible the door seal on the top of the door is failing.
Apr 13, 2014 | Kenmore Electric Smooth Top Stove
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
I have a Kenmore Elite Gas Range. #790 series. The electronics of the oven seem to be working, but the oven is not getting hot. The stove top (surface) is working. Do you think it is the pilot light? ...
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Jan 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 95022 / 95024 / 95029 Electric Kitchen Range Logo
150 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
