Question about Mitsubishi VS-45607 45" Rear Projection Television
I have a Mitsubishi VS-5004R and do not have tyhe code and cant unlock the tv
  • Anonymous Dec 31, 2008
    I have the same problem did you ever get the code?
    President:
  • 2,653 Answers
Found this solution:
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY PAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Source: Bob Waterman
Let me know if that works
--RescueTechLA
p.s. Do you have the original remote still?
Posted on Dec 04, 2009
I need a code to unlock my TV its a VS-5004R mitsubishi TV?
Posted on Dec 07, 2008
Mitsubishi VS-5004R
oh its a serious problem first find out the user manual and check whether there is any thing about this in it.
Dec 20, 2007 | Televison & Video
Mitsubishi tv
you will need the remote to unlock
the set try this link here for the
remote
http://www.remotes.com/
you might try this with the remote
press 9 and qv at the same time on the
remote
Dec 05, 2007 | Televison & Video
Do not have original remote. using. .... how do
You will need the orginal or replacment remote to unlock the set if you do not know the unlock code.
You can get a remote from www.remotes.com.
After that you can post back to me and I will tell you how to unlock it.
Sorry, but this is the only way to unlock these sets, aside from calling out a technician to unlock it for a service call.
Please let me know.
I am here to help and I do this for free.
asnowman
Dec 08, 2009 | Televison & Video
I have a Mitsubishi VS-5004r 50? TV. Two
Brian:
Have you just tried to unplug the A/V for an hour or two and then re-plug the power back in and try turning it off to see if this 'power off tactic' cures the problem?
The reason for the code is for a qualified service tech to go into the service menus for adjustments.
web site below about the code issue: http://www.answerbag.com/q_view/965160
Blessings,
A/V Media Tech Guy
Dec 01, 2009 | Televison & Video
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Child lock is on
can you please help me unlock the personal code password for a mitsubishi vs-5003r tv.
Nov 18, 2008 | Mitsubishi VS-55707 TV
I have a Mitsubishi VS-5004R and it goes to a black screen but the sound still plays. If I leave it unplugged for a while it will come back on but goes out after 20 or 30 minutes. What could be the...
Bad capacitors made by Rubicon in many power circuits......
pull chassis...look for over-heated areas for repair in horiz,vert.
and power supply,check any / all caps with ESR meter.....T.
Mar 19, 2008 | Mitsubishi VS-5076 50" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Lockout
have a tech lift off the eeprom or the microchip out of the set,that will rset your tv.and bring it back to normal.good luck.
Apr 06, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
537 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
