Question about Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood with no sound
Replaced factory stereo with Kenwood KDC-MP538U in a 2000 Dodge Ram Van. Hooked everything up, good connections, etc,Unit powers up everything visually appears to function, but no sound what so ever. Can see graphic equalizer working, etc
  • Anonymous Mar 08, 2009
    Same problem
Just had the same prob. you probably did not have the factory amp hooked up . its a blu wire on the factory harnes. if you used the aftermarket conversion harness. you would hook up either the remote wire or the elcect ant. wire. both blut with white strip on most decks. mine was also a dodge car. i had the prob on.
Posted on Jan 19, 2010
  • 580 Answers
Check your ground wire
Posted on Jul 08, 2009
2ooo Ford Mustang,Got MP538U TUNER work. cd look like it was playin no sound though.Exchanged it for MP638u.SAME BULL. cAR GOT ripped out mach system. Carstereo wires without harness
If you are wiring a Kenwood KDC-MP638U to a 2000 Ford Mustang, then below information may be of help:
  • to my knowledge, the original stereo unit uses 2 8pin connector and a single 7 pin connector;
  • if the connector with the harness has been cut, then wire splicing may have to be used based below;
  • If you are using external amplifiers, then it is possible to trigger/switch them with the blue/white wire and their RCA INputs connected to the appropriate RCA OUTputs of the Kenwood;
  • Additionally, the KDC-MP638U has built-in USB port/interface.
  • Incidentally, if what was previously installed is a full Mach system, pls be informed that there are seven (7) versions from Mach 1000.0 to Mach 1000.7, which one was installed?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Kenwood Car Audio & Video
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Jan 06, 2015 | Kenwood Car Audio & Video
Kenwood kdc mp242, no sound, ford explorer, 94
if that ford had premium sound you have either not hooked up the factory amp or you have blown a fuse to it. you won't get sound unless that amp is hooked up.
Jan 03, 2010 | Kenwood Car Audio & Video
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood kdc-x592 No sound on CD and..
your amp turn on is hooked to the power antenna wire. Swap the blue wires and youll be good to go. Since the power antenna is not needed, when the radio goes off tuner, the 12V signal is turned off. and your amplifier will also then lose its remote turn on.
Reverse the 2 blue wires.
Dec 28, 2008 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP538U does not save settings like time and date
I have had the same problem, my problem was that i accidentaly hooked up the constant wire to the switched, and the switched to the constant, causing it to turn off completely, resetting everything. So if this is the problem then just switch the wires in the back of thew head unit, should be the fatter yellow wire, and the fatter red wire
hope this helps
Nov 20, 2008 | Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
No sound coming from my factory speakers
Hey Eric, I had the same problem with my 2000 GMC Yukon and because of the OnStar connection in these vehicles you must get power to the factory amplifier which can be done by running a relay wire from the blue remote wire or the power antenna wire to either the pink or green wire on the extra pin adapter that you unplugged from the back of the factory unit. Hopefully you have figured this out by now but for future readers this solution should be helpful.
Sep 18, 2006 | Kenwood KDC-X459 CD Player
Kenwood KDC-MP538U Car CD/ MP3 Player Logo
369 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
