Question about Gateway Computers & Internet
Hard drive problems. Technical imformation (0x00000024) (ox00190444,0x860cDEE8.0x00000000)
    Champion:
  • 200 Answers
Ok my friend
go to safe mode
disable every security system (antivirus or antispyware).
run defragmentation on ur C drive
by RIGHT clicking on my computer and then select manage
select disk defragmenter and continue
at the end
go to start
go to run
type cmd
hit ok
type this command
Chkdsk /f /r
hit enter
reboot the computer
hope that will fix it
cheers
Posted on Aug 30, 2008
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
My samsung exsternel hard drive is full of imformation but it wont format to my labtop ,what can i do to get my imformation off it
you should be able to go: my computer, right click your drive, properties, reformat drive.
Good luck
May 25, 2011 | Computers & Internet
Cannot format hard drive message appears : hard disk cannot be formated" all 20 hard drives on different computers giving me same problem
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the hard drives what procedure??? will need more imformation a hard drive must be formatted from a ""third party disc""
Apr 09, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
The problem I'm experience with my computer start when a blue sceen appears. The statement states: A problem has been dected and windows has been shut down to prevent damage to my computer. If this...
If you are running Windows XP, the boot to the XP CD, press R when prompted to access the Recovery Console, then run the command CHKDSK /R at the C:\windows\system32\ prompt
If you get indications of recovering lost allocation units, then the disk surface of the HDD is likely bad and the HDD will need to be replaced.
If running Windows Vista or Windows 7, boot to the Windows DVD and select REPAIR MY COMPUTER
Dec 23, 2010 | Dell Computers & Internet
My Dell Inspiron E1405 is getting the blue screen of death before starting up windows xp. It has the stop codes 0x00000024 (0x001902FE, 0xF8C7E4D4, 0x0F8C7E1D0, 0x83622816) it tells me to uninstall any...
STOP 0x00000024, 0X0000024, 0X24 or NTFS_FILE_SYSTEM = this stop error means that your NTFS file system is corrupt and this is practically impossible to fix - absolutely everything on your hard disk is trashed. The only reliable way to fix that is to reinstall Windows.
Nov 02, 2010 | Computers & Internet
0x00000024 (0x00190203,0x873222B8,0xC0000102,0x00000000) Ok so i start up my computer and it lets me get all the way to the part when it shows the logo and it loading and then it always at same part it...
usually 0x00000024 is when you hard drive has gone bad you can try to do chkdsk /r but also try to do a windows reinstalltion but usaully it happens again as the hard drive get bad sectors .
Apr 17, 2010 | Computers & Internet
Can not start laptop and get the following blue screen below..
In cases like this I have an IDE / SATA to USB adapter that I use to connect the removed hard drive and access it on another computer so I can scan, delete and repair the files. The adapters are sold at computer retailers or Ebay for about 20 bucks. This way no files on the drive are being used and all of them can be scanned without missing anything. It also allows you to use disc management to test and diagnose the hard drive itself.
Oct 20, 2009 | Dell Latitude E6400 Laptop
***STOP:0x00000024 (0x00190203, 0x8A811CA0,
Could be a number of problems, including but not limited to...
1) NTFS file structure is corrupt
2) MBR has been compromised (corrupt)
3) ATA/SATA drivers are corrupt
4) Hard drive is on the way out
Boot your computer using the OS install disk, and run CHKDSK /f from within the recovery console. CHKDSK /p will repair a corrupted NTFS file system (if that's the problem).
If CHKDSK options don't fix the problem, or if the drive is not recognized by your OS, it may be your MBR (Master Boot Record). Use the command fixmbr from within recovery console, then reboot.
MBR may be data destructive, so it's best to use CHKDSK options first. Also, if you are able to get the system to boot up, you'll want to save/recover any data on the hard drive, then run thorough diagnostics on the drive to make sure it's not on the way out (contact Dell for further information regarding this).
Hope this helps!
Aug 16, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
