Question about Handspring Treo 300 Handheld
Hot Syncing
I never have hot synced my Treo 600 with my laptop. I am presently wireless connected from my Treo and Outlook through my email service & Goodlink. If I hot synced at this point, would I lose all my existing contact information?
0 characters
1 Points
Not hot syncing
I just reset it and it work. You can reset it by taking the battery out for a couple of mins, put it back in and it should work just fine.
Oct 05, 2008 | Palm Treo 755p Smartphone
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
Calendar Not Syncing
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Outlook Express
You cannot sync treo with Outlook express because of the Outlook express limitations However you can sync with Outlook
Sep 12, 2005 | Palm Treo 600 Handheld
Override
What you're talking about is what is called a "collision" when it comes to syncing devices. You use the options in the hotsync manager to decide how to handle collisions.
Open Palm Desktop.
Go to Hotsync->Custom
Pick the outlook calendar conduit
Select if you want to synchronize intelligently, have outlook overwrite the handheld, or have the handheld overwrite outlook.
Typically if the treo detects both records on outlook and on the treo, and you've set it to synchronize intelligently, it will make dupliate records and post a message at the end of the hotsync operation.
Sep 11, 2005 | Palm Treo 600 Handheld
Acrobat reader for Treo
Go to www.adobe.com, select "downloads", then select the acrobat reader. When it starts walking you through the download process select "other" when you get the option from the platform. It will then give you a pull down box. Select PalmOS and download it to your PC. Run the install program. During that process it will ask you to hit the hot sync button and will download the reader to the phone. Once you have the reader client installed on your phone you run the PC side which will take a standard PDF and shrink it down for your Treo 600 and download it through the hotsync process to your Treo
Treo 650 from Cingular is not hotsyncing with Outlook Calendar?
Have you setup an EAS account in VersaMail? The VersaMail application on your Treo 650 supports Exchange ActiveSync, which allows synchronization of Email and Calendar wirelessly with Exchange Server 2003. If an EAS account exists on the handheld the Calendar conduit will disable itself to avoid duplicates. Go to VersaMail on your Treo650 Select Menu: Accounts: Account Setup Check to see if any EAS accounts exist on the device by selecting and account, then Edit... One the first screen check Mail Service. Do any of them say "Exchange Activ..." If yes you'll need to delete that account to sync calendar entries.
Sep 07, 2005 | Palm Treo 650 Handheld
Handspring Treo 300 Handheld Logo
Top Handspring PDAs Experts
yadayada.
yadayada.
fgg3
ray gallant
Are you a Handspring PDA Expert? Answer questions, earn points and help others
