Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
PC Display after booting
Hello there,
I get problem with my pc. Every time it completes in booting, there is no display on monitor except the background. the task bar, shortcut icons are disappeared.
what i can do right now is opening my pc in safe mode.
Please advice as solution.
Thanks
Edison
    Sergeant:
  • 336 Answers
Okay this is a flaw with XP. what you need to to is when that happens. Wait for the screen to load and press Ctrl+Alt+Delete and that will bring up task manager. Under the file button on the top right hand corner and select New Task (Run...). Then the run box opens up and type in the box EXPLORER.EXE that should show the task bar and shortcut icons. If you need any more help just ask me.
All The Best,
RCF
Posted on Aug 30, 2008
Packard Bell OneTwo M3700 PC boots up but no display
most of the time on older monitors you can set the refresh rate in safe mode and that will, most of the time, resolve the problem otherwise time to purchase a newer monitor.
Jun 26, 2015 | Packard Bell Computers & Internet
Monitor is in slef adjust mode how can i turn it off
Trussell43,
System setup Disks do not have any relation to your Monitor unless it is an All-In-One PC or a Laptop.
If you can see display when the unit is booting, but not when Windows should be displaying the Desktop, then your Display Size has been set outside of the size limits or refresh rate of the monitor.
An IT Technician could help you boot the PC in Safe Mode to remove the Monitor and let it re-install. This should forward the instructions to Windows to re-detect the monitor and the display limits it has.
If you have no display at any period, try another monitor.
I hope this helps.
Nov 13, 2012 | Dell Dimension 2400 PC Desktop
No disiplay on the screen of the laptop and on the external monitor
No display on either? Does it sound like the computer completed the boot cycle? Do you hear fans running and the hard drive spinning?
What happens when you hit the power button? Do you hear any beeps or see any blinking lights? Does anything post to the screen during the boot cycle?
If the boot cycle completed and you see no display on either monitor, then your video card is bad.
Apr 09, 2012 | Acer Extensa 5630-6806 Notebook
Acer laptop no disiplay
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Power Supply
If you are not getting even the Motherboard boot singal, then, its a power card issue. Please check the power cable to the monitor.
Regards,
HP
Aug 28, 2009 | Gateway GT5228 PC Desktop
Blank screen after boting up
There should be a display toggle key on your keyboard. This will toggle the display from the external display to the laptop lcd. Try pressing the Fn + F5 key to toggle the display.
Jun 10, 2009 | Acer Extensa 5620 Notebook PC
Is nvivia gforce 7300 compatible with a6010n hp motherboard
if your PC has a built in graphics adapter then the bios and windows will automatically use that as a primary display unit..u need to boot the PC with that and then check in the device manager if the PC has picked up on the new display unit.. if it has then disable the on board one. the pc will ask to restart ... do it.. then when it does connect the monitor cable to the new display device.. and make sure that the monitor has an image of the start up screen if it does then you have completed the upgrade
Jan 08, 2009 | HP Pavilion A6010N (882780985575) PC...
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
No display
Your monitor's signal cable is loose.Tighten the screws of the cable....
Oct 12, 2007 | E-Machines T2615 PC Desktop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
