Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson dc07 animal
My vacuum will work for 5 minutes or so, then shut off. I will have to wait another 5 or 10 minutes, then it will turn on again, only to shut off after using it. Please help!
  • 114 Answers
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Posted on Aug 30, 2008
My Dyson DC07 Animal will not turn on
it could be one or two things broken switch/ cable broke/ or fused, this video below will help if you need new switch
http://www.videojug.com/film/how-to-replace-a-dyson-switch-and-actuator-dc07
Jan 01, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
DC07 Shuts Off, won't restart
If it was running for a while... It may be overheating. It has a reset: http://www.ehow.com/how_5943288_reset-dyson-vacuum.html
But maybe just let it cool for an hour or two and try it again?
Oct 07, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Why does my DC17 Animal vacuum keep shutting off?
Hi Emmeline,
I'm sorry to hear you're having difficulties with your DC17. From what you've described, it sounds as if the thermal cutout feature is shutting the machine down to prevent overheating. If you've already tried washing the filter and are still experiencing the issue, I'd encourage you stop using the cleaner and to contact us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum will run for 5 minutes and shut off,
Your Dyson is designed to cut out if it becomes overheated, and it then takes about half an hour to cool down properly. If you don't resolve the problem, it will soon cutout again. Clogeed filters or other blockages are the usual cause of cutting out, but there are others, for example, incorrectly fitting valves, or broken belt. You need to do more cleaning. Follow the step by step instructions for your model, which can be found here.
http://www.dyson.co.uk/support/help.asp?article=51&product=DC07-ANIMAL
You will be following a path for solving cutting out when you are using the machine, and I would be surprised if you can't fix yours.
Jul 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson animal shuts of after 5-10 min of use
The "hidden" filter at the base of the unit is the HEPA filter, there is another filter on the side of the vacuum that you can remove and wash with water. Make sure that is washed out. If it's too dirty it will restrict air flow and the motor will overheat.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Apr 02, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Power Loss - Suction Loss
Hi
Its cutting out because its overheating.
Change the filters and check the base and the hose for blockages
Feb 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 shuts down after 5-10 minutes of use and horrible suction!
I have had this problem on two dysons and have solved it by replacing the so called lifetime pre-filter. The problem is not the washable blue sponge but the material gauze filter in the plastic surround.
To see if this is your problem try removing the whole filter (i.e. the filter with the blue sponge inside - you need to remove both bits not just the sponge).
If you do a quick vacuum test for a few minutes then see what effect this has on the suction.
If you need a new part try somewhere like here (you'll need to chose for the right model) : http://www.espares.co.uk/part/dyson/dc07/p/1086/716/6/420625/875479/lifetime-pre-motor-dyson-.html
As I say this has fixed both of mine.
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
397 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
