Question about Orion STV2763 27" TV
Remote and TV/AV Button
Our original remote quit working - while we can get universal remotes to work the general functions of the TV - what we cannot do is connect to our DVD player or Playstation without the TV/AV function button. I am sure there is a simple way to do this but I cannot figure it out. I looked up getting a replacement remote like the original and they discontinued making the one we had and the replacement remote doesn't have the TV/AV button on it either. Please let me know if anyone has any advice.
  • CliffShep Sep 16, 2008
    I lost my remote and now I can not get the tv to go into input mode using the menu buttons.
    Can someone help me out?
  • watermanwife Sep 28, 2008
    I thought you could switch input modes using the universal remotes. I can get to Aux 1 and Aux 2, but the input from the DVD or VCR does not show on the screen. I have tried with the AV matrix off and with the AV maxtrix on. What is the problem?
  • 85 Answers
If you take the remote control apart,look for any signs of spillage ingress.very common,especially if you have kids.thoroghly wash the large area with the black tracks,the rubber keypad too,and dry all gently with a hairdrier for twenty mins or so.fixed.other common problems may inlude a broken lead on the yellow or blue resonator,or on the infra red transmitter diode,.its top centre of the board.failing this try grandata,based in wembley,middesex.they are online.hope any or some of this helps,regards,steve.
Posted on Nov 05, 2008
I want to activate the AV on the remote the stang remote but it's not working. What do I do?
Some universal remotes are not really universal. Some functions of your device may not work.
May 12, 2017 | Universal Televison & Video
Put tv av mode without
To select its inputs, you should have its original remote control. No universal remote can go with this function. Gopakumar Gopalan Google
Feb 11, 2014 | Radio Shack Televison & Video
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
My remote for my Orion tv quit working. I purchased a Universal remote but it does not have an AV/TV button. How can I access the AV ports without a remote or is there a replacement remote I can use?
Hello
You just buy one [CISCO-6400 ] Universal remote control to which your Orion TV is listed in its codes, and have all the buttons you need. Just go for it. It is a good one I thinks. Codes for Orion are:- 1023_1033_1107.
Keep trace with its manual to alaigh the remote to your TV.
OK.
Jan 05, 2011 | Orion STV2763 27" TV
I changed the cabling between my Phillips tv and set-top box a few times and I lost the signal. The signal is from UPC, it's piped tv. They said to locate the av channel on the tv and this would restore...
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
Dec 29, 2010 | Philips 32PW6506 32" TV
How do i get the av button on with my universal remote urc22b to play my ps3
Most of the universal remotes controls.The AV button dosen't work the same exact functions to all the tvs models.That why u should alway buy an exact remote to ur tv the original remote.The original remote cost u like 5 times more $ but it is the best way to get into ur tv inter functions,most of the universal remotes can't.Try website like Remotes.com to buy an exact remote to ur tv original remote.
Nov 06, 2010 | One For All Televison & Video
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Jan 11, 2009 | Durabrand BH1304D 13" TV
Tv is in AV mode
you would need to purchace a universal control you can find these in shop like currys ask the teqs there or look on ebay for a remote like your old one
Dec 28, 2007 | Durabrand BH1304D 13" TV
Orion STV2763 27" TV Logo
248 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
