Question about Yamaha YST-MSW10 Computer Speakers
Sound card in PC is operable
The sound card in my PC is operable since I can get sound directly through the two little speakers that came with my PC. However, when I use the Y cable connector to the speakers, I get no sound from either the Yamaha subwoofer nor the pair of little Creative brand speakers. I have tried going directly into the Yamaha speaker via the Y connector from the 1/8" female outlet on the back of the PC. That didn't work. Then I plugged the Creative speaker pair back into the PC and plugged the Yamaha subwoofer into the headphone jack on the pair of Creative speakers. That didn't work either. Back to the original setup with the two little speakers and I have audio through those. Any suggestions?
Bill Bacon, Seattle, Washington
  • hammondbacon Aug 30, 2008
    Oops, my error! It's the 1/8" plug going into the back of the PC that is metal, band, metal, band and then metal. The two Y connectors, right and left, have no banding.
    Brigadier General:
  • 5,158 Answers
Look at the plug.... is it metal then a little band and then the tip or is it metal a band then metal and then the tip.
Posted on Aug 30, 2008
My speakers have very little sound. I have the volume on high but the sound doesn't increase.
Make sure the Master Volume is up and that you have your preferences set for your particular speakers and sound card. It could also be a bad diode in your speakers or on the audio card.
Sep 12, 2013 | Lenovo Computers & Internet
I have an older altec multimedia 3 pc. computer speaker system my software has been damaged and I need drivers the subwoofer is a ACS160 and the speakers are ACS55
These speakers should work as long as your computer has the drivers for the sound card. I need to know what sound card you have, make and model of the computer, and the operating system; in order to direct you to the driver download. If you know of a computer with an operational sound card, test them on it. The speakers are passive devices - they don't need drivers to operate.
Feb 11, 2011 | Altec Lansing ® Multimedia 3pc...
I dont have ani more cd drive
The X-530 are analog speakers. They do not require drivers, your sound card does. You should install the Sound/audio Drivers for the sound card.
What is the PC configuration ? Let me know the PC model and operating system or the sound card you are using for further help.
Regards,
FixYa
Nov 16, 2010 | Logitech X-530 Computer Speakers
No audio driver installed after reformatting my PC
Direct sound is actually referring to Direct X drivers. Do a search for Direct X drivers and download and install the correct ones for your sound card and operating system. Also, if you think your sound card drivers maybe part of the problem go to the Sound Card manufacturer website and download the drivers for your sound card and operating system.
Jul 07, 2010 | Audio Players & Recorders
Dell Dimension 4700 PC Speaker No Sound
Check to make sure all cables are connected. After this you will need to click on your sound card properties and set it to 5.1. which will allow all the speakers to play.
Please note you will need to have a card that supports 5.1 sound I do not believe the stock card in the Dell supports this feature which could be the problem.
Feb 05, 2010 | Dell Dimension 4700 PC Desktop
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
Headphones will not work but speakers will.
Plug the headphones directly into the speaker port on the sound card, check for a mute button on the headphones. try another set of headphones to double check wether the first set is working.
regards..
Apr 05, 2009 | Dell Dimension 4600C PC Desktop
5.1 SPEAKER SETTINGS CHANGE AT EVERY RESTART
having multiple os's should not effect the settings it sounds like something directly related to the software you all are running for the surround. what is this sofware and is it updated, does it belong to the sound card or the speaker setup ?
Apr 09, 2008 | Altec Lansing VS3251 Speaker
Low sound from speakers.........polk audio speaker
Hello Minikish
well, some DELL models, have an internal audio, and it is cheap sound card, others have problems with this sound cards, and must be replace. or if you want to buy a PCI X-FI from creative, really Rocks the sound to a new level 5.1 surround sound, up to 7.1
Dec 06, 2007 | Audio Players & Recorders
Dell A215 Speakers
I think you probably have an issue with your sound card and/or its drivers. What model PC and operating system do you have?
Jul 15, 2007 | Dell A215 Computer Speakers
Yamaha YST-MSW10 Computer Speakers Logo
186 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
