Question about Toshiba Satellite A105-S2716 Notebook
No video When power on the screen lights up but black no video. when you hook up an external monitor it says "password" on the upper left side of the external monitor. Is there something wrong with my lcd screen?
  • 1 more comment
  • bot64m Sep 02, 2008
    yes, it boots up. But when I used my laptop screen (external unplug) you know that screen lights up but black. when i punch in the password i can see the hdd runs that means its booting up but no picture on screen. ould it be the lcd screen?
    Thanks
  • bot64m Sep 03, 2008
    I've fixed the problem now. I've updated the bios and the video came on.
    Thanks
  • David Leahy May 11, 2010
    Perhaps there are 2 things here:
    The laptop is set to boot to an external monitor firstĀ
    There is a Boot password
    Have you tried entering the bios/boot Password
    Scholar:
  • 113 Answers
Well done, it's a great feeling when things work out
Posted on Sep 03, 2008
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
Hp g61 notebook pc bios blink error code 2 black screen led lights above num lock key and led lights to left of caps lock key flash 2 blinks.no monitor when hooked up to an external monitor.cd disc drive...
If screen and external monitor do not work then the issue lies with the video section of your laptop. The video chip is soldered onto mo bo and there is noway you can replace it if bad. Kiss your laptop sayonara, salvage the hard rive and memory and get yourself a new laptop that works. And avoid HP - their customer service is non existent after warranty runs out. They refer you to a forum or tell you to get another unit - an HP of course!
Sep 08, 2017 | Computers & Internet
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
Laptop powers on but display does not power...
Hook a external monitor to the video output on the back of the laptop, if the monitor works! there is an issue with the computer display. The inverter board is bad, or the back light behind the LCD screen. If both displays show black, it is the Video Graphics Board that is part of the motherboard.
Jan 13, 2011 | HP Compaq nc6000 Notebook
Acer Aspire 3100 Laptop Monitor will not turn on
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Dec 17, 2008 | Computers & Internet
Black screen
One way to test it is to connect a monitor to the VGA port (make sure to activate the external monitor (Fn+monitor key)
If it does work on the external monitor, I would look at replacing the onboard LCD.
If it doesn't, you are looking at problems with the onbaord video.
Aug 05, 2008 | Toshiba Satellite A105-S4334 Notebook
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Jun 29, 2008 | Computers & Internet
Acer laptop has black screen but power light is on
Does it appear to be doing anything. Is there a flashing "_" at the top left of your screen. If not try hooking a monitor up externally and turning the laptop on.
Dec 23, 2007 | Acer Aspire 3610 Notebook
Toshiba Satellite A105-S2716 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
