Question about Lexmark X3470 All-In-One InkJet Printer
Scanner & Printer X3470
I downloaded the update w/drivers. Have them on my PC. Don't know how to get them to operate. Microsoft gives me a sign saying driver not installed and No comunication to the printer. Thanks, 1234asdf@tds.net
  • 4 more comments
  • UNCLE JIM Aug 30, 2008
    Bunny dog, Little more complicated. Down loaded as you said. not working.
    Two messages: From Microsoft Visual C++Runtime library.
    Program:C:/Program Files/Lexmark 3400 Series/excyalox.exe
    This application has requested the run time to terminatein an unusual way. CONTACT SUPPORT TEAM.
    SECOND: EZ printer says printer out of memory.
    Thanks, Uncle Jim
    Bunnydawg, Robert, I took step two. Now there comes up a sign
    lxcycfg.dll needed. They want the path to it.
    Thanks, Uncle Jim.
  • UNCLE JIM Aug 31, 2008
    Anybody, Been working w/Bunnydawg, but can't get an answer.
    Problem: Try to run printer. Sign comes up (Path to lxcycfg.dll on Lexmark is needed. My model is X3470. Thanks, Uncle Jim
    1234asdf@tds.net
  • UNCLE JIM Sep 01, 2008
    Thank God! & you and Bow Dawg. Couldn't go back to an earlier date. PC wouldn't allow. Dumped old program and went back to Bow Daug's earliest solution. Started down load again and Driver Detective jumped in and helped. Finnaly success.
    Thanks a bunch to all of you.Uncle Jim.
  • UNCLE JIM Sep 09, 2008
    I got the thing to work but about the 8th copy sign came up out of ink. went to WalMart and got a #1 refill cartrudge. Installed it only to have a sign come up on printer saying cartridge incorrect. Needless to say (How fix) Thanks, Uncle Jim
    1234asdf@tds.net.
    Genius:
  • 1,665 Answers
Make sure correct drivers acoording to your operation system are installed. Uninstall re-install and try again.
Posted on Sep 09, 2008
  • 2,071 Answers
Step one: Restart the computer
  1. Click Start .
  2. Click Shut Down .
  3. Click Restart or select Restart from the drop-down menu, if available.
  4. Click OK .
  5. Check the print queue, once the machine is restarted. If this step does not resolve the issue, continue to the next step.
Step two: Check the printer cable
  1. Disconnect the USB cable from the printer.
  2. Disconnect the USB cable from the computer.
  3. Leave the cable unplugged for 5-6 seconds.
  4. Reconnect the cable to the printer and computer. Ensure that the printer is connected directly to the computer through a USB cable or a powered USB hub.
  5. After reconnecting, the printer should start printing the jobs in queue. Go to step five, if you want to stop those jobs from printing. If this step does not resolve the issue, continue to the next step.
Step three: Check for the right driver and port If there is more than one printer configured on the same computer, the printer in use may not be the default printer, or the wrong driver may have been configured. Use these steps to verify the driver configuration:
  1. Click Start .
  2. Click Settings .
  3. Click Printers or Printers and Faxes .
  4. Ensure that the correct printer is set to default, denoted by a checkmark in a black circle on the icon. If the wrong printer is set to default, right-click the icon for the correct printer, and then click Set as Default .
  5. If the printer is already set to default, right-click the icon, and then click Properties .
  6. To verify that the printer is using the correct port and driver, click the Details tab. The printer should be set to use a DOT4 or the USB00X (where X is replaced by a number) port. The Print using the following driver drop-down list shows the printer driver in use.
  7. Click OK to close the Printer properties window, and then close the Printers window. If this step does not resolve the issue, continue to the next step.
Step four: Check whether the printer is paused or offline
  1. Open the Printers folder.
  2. Right-click the icon of the printer in use, and then click Open .
  3. Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
  4. If neither Pause Printing nor Use Printer Offline are checked, press Esc to leave the menu without making changes. Hope this help you;
Regards,
VOTIT
    Scholar:
  • 163 Answers
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
  • Lexmark Master
  • 19,396 Answers
You first need to download and install drivers here:
DRIVERS & DOWNLOADS -- Lexmark.
Unplug printer before installing drivers.
Posted on Aug 31, 2008
  • Ginko
    Ginko Aug 31, 2008
    If you have printer disk it is even easier to install printer driver software from disk.
    It is important that your printer USB cable is unplugged when you start driver installation, or you can get error messages afterward.
    If you have the printer disk just put it inside and run software again with printer unplugged.
    If printer was working before try doing a system restore instead, here is the how to:
    System restore it is often the first tool to solve problems on your computer.
    Each
    time you do an update, or install a new software, system settings will
    be modified, sometimes this can cause Windows operative system
    malfunctions.
    System restore to a date before you had the problem can repair most Windows faults.
    Here is the how to:
    Before starting System restore close all this running applications.
    You can start System restore from start menu:
    1.
    Click Start.
    2.
    Point to All Programs.
    3.
    Point to Accessories.
    4.
    Point to System Tools.
    5.
    Click System Restore.
    6.
    Follow the instructions on the wizard.
    You can also start system restore to create a restore point before making an important change to the system.
    For example you can decide to create a restore point before installing a new anti virus, or downloading Internet Explorer update.
I have a Lexmark X3470 printer. I have recently bought a new computer and when I insert the sim card from my camera the following message comes up. Cannot find 'File:///C: Windows/system 32/spool/
You didn't install d drivers properly. Do it over and
you'll see the difference. It says that because its looking for the root folder for the printer but since its not installed properly it can't find the folder.
AKJR
Jan 31, 2013 | Lexmark X3470 All-In-One InkJet Printer
Don't have a disk
Please visit the Lexmark website to download and install the Lexmark X3470 printer driver on your computer. Select your operating system versison > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to successfully install the printer.
Note: The Lexmark X3470 printer works on Windows operating system only.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Thanks.
Oct 18, 2011 | Lexmark MFP-X3470 All-In-One InkJet...
Can i down load the disk to make my old printer work
Oct 18, 2011 | Lexmark X3470 All-In-One InkJet Printer
I have rescently changed computors and i ned to insatll my lexmark x3470 printer but have lost the cd could you please help
You can download the Lexmark X3470 driver (for Windows only) from the Lexmark website for free. Click on this link Lexmark X3470 Drivers. Select the version of your Windows operating system. Download, execute the file and follow the instructions on the software. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark X3470 All-In-One InkJet Printer
I couldn't use my lexmark 3470 scanner,please help,
Some Lexmark printers have to download the Application List, before they can scan. It might take 3 or 4 times for the printer to get it downloaded, don't ask me why. I don't know what else to tell you, you didn't say much about the problem. Do you have your cord hooked up to the USB port? Did you install the CD that came with your printer? Is your printer showing up in the Control Panel, letting you know the drivers are installed?
Mar 19, 2010 | Lexmark MFP-X3470 All-In-One InkJet...
Can't scan from my x3470 to my pc
Hiya,
Here is the link for you to download the user manual, and this should hold of your answers to any problem relating to your problematic product.
http://www.retrevo.com/support/Lexmark-X3470-Multifunction-Printers-manual/id/409dj094/t/2/
I personally think it is a software issue, in the form of the utility download or a driver that is missing. So the link for the software is listed below.
http://drivers.softpedia.com/get/PRINTER/LEXMARK/Lexmark-X3470-Printer-Driver-1060.shtml
This is assuming you have Windows XP as your operating system. If not, then you might need to download the driver direct from lexmark.
I hope that this is the fixya for you.
Yours sincerely
Oz
Feb 25, 2010 | Lexmark X3470 All-In-One InkJet Printer
I need the software disk or a download site for installing a LexMark Z611 on a new computer.
This is what I did to find the driver necessary to install your printer to a new computer:
1: Visit Lexmark's Driver Download Site.
2: In the section that reads, "Download by Product" type in: Z611
3: Click the image/link of your printer (might take a moment to appear above the text-area).
4: Scroll down and find the appropriate driver that corresponds to your Operating System (If you have Windows XP, download the driver for XP. If you have Windows Vista, download the driver for Vista).
If the method above does not work for you, Microsoft has been getting better at locating drivers for you through Microsoft Update. If you're running Windows XP, go to the regular Windows Update page and look for links for Microsoft Update (By default, Microsoft Update is not used for Windows XP. You have to request it through Windows Update). After "signing" an agreement and installing a few more files Microsoft Update will look for updates to your system. Once the results are displayed look into the "Hardware" section. If you find anything in regards to a printer, chances are Microsoft found a compatible driver they know will work for your printer. Remember, before Microsoft Update can locate drivers for your printer it has to be connected to the computer and turned on.
If you're using Vista (W7 is just an enhanced version of Vista, yet Vista nonetheless), just go to your Start Menu and search for Microsoft Update -or- Windows Update. Afterward check for new updates and do the same as mentioned above. Look into the hardware section to see if there are any entries for a printer. If there are, select the update and install it. Remember, before Windows / Microsoft Update can find drivers for your printer it needs to be connected to the computer and turned on.
Personally I would use the drivers from Lexmark, yet I figured I would give you two choices. Let us know how things turn out.
Dec 29, 2009 | Lexmark Z611 InkJet Photo Printer
Since downloading a Microsoft update my HP PSC500 does not work
Try re-installing the driver or rolling back the driver and re-installing. maybe even check the manufacturers website for further updated drivers
May 07, 2009 | Office Equipment & Supplies
My X3470 printer needs to be installed
You haven't told us the computer's operating system, so you'll have to do a little digging yourself.
http://www.lexmark.com
Drivers and Downloads
Driver Finder
Start typing X3470. The name should appear as you type -- click on it, and you'll see some options to download the driver.
Dec 05, 2008 | Lexmark X3470 All-In-One InkJet Printer
X3470 user guide
i need help reinstalling my printer
Mar 02, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
