Question about Dishwashers
My LG dishwashermodel #ldf7810 is leaking at the bottom of the door on the left hand side wondering if its the seal around the door.
  • Anonymous Sep 25, 2008
    any luck fixing this problem? I have the same issue, mine is leaking from under the door. HELP...
  • 107 Answers
If it is leaking @ the door and not from under the washer then I would inspect the seal for damage. If it is coming from under it can be the water supply or the discharge line.
Posted on Aug 30, 2008
My black LG 24 builtin dishwasher has suddenly started leaking about 1/3 cup of water around the bottom vent on the door (LH side). How do I make adjustments to the door to stop this? I have already...
Check the door seal. To do this, make sure the door and the rubber gasket is complete dry. Apply a liberal amount of liquid detergent around the rubber gasket. Then close the door. Open the door and look for the liquid detergent to transfer onto the door. If there is a gap, then you will need to replace the door seal.
Jun 17, 2011 | LG Dishwashers
Leaking water on the right hand side
Does it seem to be coming from the door it self or from underneath the unit?
If it's coming from the door, check the seal or maybe replace it. It's easy enough and cheap.
(disconnect power before proceeding to the next step)
If it's coming from underneath the unit, first start a cycle to drain it then stop it. Pull the unit out and flip it to its side(have a couple towels ready), then remove the bottom cover and check hoses connects or any signs of leakage.
Feb 23, 2011 | LG 24 in. LDF7810 Built-in Dishwasher
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Leaking door seal
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
mmb
Jan 30, 2010 | LG 24 in. LDF7810 Built-in Dishwasher
LG LDS 5811 has started leaking at the bottom of the door left hand corner.
Could be 1 of 2 things.
1: Open door and look for any" Obstruction" Between the Door Seal and the Dishwasher.
2: the Seal is Warped from General useage or, twisted.
hope that helps
Please Rate Me
George
Apr 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Mar 16, 2009 | LG WM2688H Front Load Washer
Door leaks
This dishwasher has a vent at the bottom left of the door that blows out hot moist air during the drying cycle. Are you sure that you are not getting condensation build up from this vented air that is dripping on your floor?
Dec 29, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Leaks from front door 2 loads AFTER too much suds
No. It is not a costly affair. Order a new door boot seal from your local agent and fit it yourself. If you lift the outer lip of the seal on the front of the machine you will see a wire that runs all the way around the seal and attatches to a spring. Remove this wire and pull the seal free. On the other side you will find a strap holding the back of the seal in place. Loosen the strap and the seal comes away. Fit the new seal in reverse order ensuring that the drain hole/s are at the bottom of the seal.
Feb 18, 2007 | LG WM1812C Front Load Washer
Dishwashers Logo
199 people viewed this question
Top Dishwashers Experts
